full time to part time
Old 03-28-2012, 05:54 AM
twwtruck's Avatar
twwtruck
twwtruck is offline
Question full time to part time
Hey guys I got a 78 full time switching to part time. I ordered warn premium hubs from broncograveyard I couldn't find a auto to manual kit. Do those old full time trucks even need a conversion kit?
Old 03-28-2012, 10:45 AM
twwtruck's Avatar
twwtruck
twwtruck is offline
Anybody know anything about it?
Old 03-28-2012, 11:01 AM
Blown 331's Avatar
Blown 331
Blown 331 is offline
I've never done it but as far as I know you will also need to swap your NP203 transfer case to an NP205. Or you can put a conversion kit in the transfer case such as this. Mile Marker 501 - Mile Marker Part-Time Transfer Case Conversions - Overview - SummitRacing.com I've heard when you put these kits in the full time case some bearing no longer gets lubed properly but thats just hearsay, I have no experience with it. Just something else you might want to research.
Personally I'd just leave it full time. I don't think the full time set up is bad at all and has its benefits, but I seem to be in the minority on that thinking around here.
Old 03-28-2012, 12:54 PM
twwtruck's Avatar
twwtruck
twwtruck is offline
Well I'm not changing the t-case just putting lockers on instead of the inserts since I'm welding the spiders in the front
Old 03-28-2012, 01:00 PM
Blown 331's Avatar
Blown 331
If you take a full time truck and put lockouts in the front axle, then unlock them, the truck will not move. There is a differential in the full time transfer case and it will just spin the front driveshaft. But then if you shift it into "LOCK" you will have rear wheel drive only. The transfer case differential will be locked so both front and rear driveshafts will turn together, but no power will get to the front wheel because of the unlocked hubs. If you are welding the spiders I assume this is not a street truck and this might be enough to accomplish what you are trying to do. Hopefully that all made sence. I find a lot of people do not understand anything about full time trucks. My dad and uncle prefer them and have had them my whole life so I'm real familiar with them.
Old 03-28-2012, 02:57 PM
twwtruck's Avatar
twwtruck
twwtruck is offline
OK so even if I weld it with out changing to lockouts will I be able to turn? Cause that's the reason I was changing to lockouts. And its a tug truck
Old 03-28-2012, 03:21 PM
Blown 331's Avatar
Blown 331
I'm not sure what the effects of that would be. If you just have to drive into position to hook to a sled or another truck I think you could do that. I'm sure turning will be affected but I don't think you'll have wheels cut all the way and just plow straight or anything like that. I'd give it a try. If its not good enough then throw the lock outs in it. With the hubs unlocked you just have to have the transfer case in lock for it to move in 2wd.
Old 03-28-2012, 03:30 PM
twwtruck's Avatar
twwtruck
twwtruck is offline
OK thanks but if I do put lockouts on do I need a auto to manual kit or do they fit right in
Old 03-28-2012, 03:32 PM
Blown 331's Avatar
Blown 331
They will fit right in. The hubs and axles are the same in part time vs full time. Instead of the lock out, a full time truck just has a solid steel sleeve with internal splines that spline to the axle and external splines that spline to the hub. Its stronger than lock outs, nothing to break.
Old 03-28-2012, 03:41 PM
twwtruck's Avatar
twwtruck
twwtruck is offline
OK I know on auto trucks you need the conversion didn't know if full time need one too. This is the first full time truck I have ever messed with. Do those inserts just pull out after you take the putter snap ring off?
Old 03-28-2012, 03:43 PM
Blown 331's Avatar
Blown 331
Its been awhile since I've been in one but yes I believe so.
Old 03-28-2012, 04:01 PM
twwtruck's Avatar
twwtruck
twwtruck is offline
OK thanks for all your help.
Old 03-28-2012, 04:28 PM
Blown 331's Avatar
Blown 331
No problem. Good luck with it.
Buck B
12-01-2014 07:32 PM
easydoesitmikey
03-08-2006 09:29 PM
JeremiahJ
12-27-2005 06:31 PM
Colo79Ford
09-03-2004 10:03 PM
Quick Reply: full time to part time
