fuel pump?
Old Mar 28, 2012 | 04:13 PM
fordnurse's Avatar
fordnurse
fuel pump?
I have a 78 351m. Over the last 2 weeks when I accelerate up from a stop to 45-55 mph my truck will chug like its running out of gas then it will pass thru it and keep running like normal..it happens without rhyme or reason but only between those speeds. I replaced the factory fuel filter this past winter so I wouldnt think its that. I do have an additional fuel filter beneath the cab of truck that I have yet to replace. But I would think it would happen at all speeds not just isolated to those I listed. How do i determine if my fuel pump is going bad? Btw I had my carb rebuilt last year so does that rule it out? It also seems like its a gas issue not a tranny issue because its not having difficuly shifting just feels like its running outta gas
Old Mar 28, 2012 | 05:08 PM
mark a.'s Avatar
mark a.
You need to put a fuel psi gauge in the line after the pump and see what it is putting out. A truck will run ok with just 2 or 3 psi but when you put a load on it, like going up a grade it will cut out. You want to see at least 6 psi all the time usually stock pumps put out about 7 psi.
SouthernBlues
Jan 26, 2013 05:40 PM
Myfreeford
Jan 11, 2012 10:07 AM
keyul
May 15, 2011 10:38 AM
jaye
Dec 31, 2010 05:05 PM
jonesn
Dec 30, 2002 01:08 PM
