P0340 code?
Old Mar 27, 2012 | 06:06 PM
f1501987's Avatar
f1501987
P0340 code?
What does this code do? Says CMP sensor circuit malfunction. The cel comes on. Like half cyndlers r running
Old Mar 27, 2012 | 07:46 PM
F350-6's Avatar
F350-6
Usually when that code shows up it means it's time to walk. The CMP (CPS) is the sensor the computer uses to read the timing of the engine to determine injector firing etc. Any other codes show up like P1316?
For the code, get yourself a new CPS from Ford (don't waste your time with the parts house versions). Then I'd also consider checking your UVCH connections for burnt pins since those can give off the rough running symptoms you're describing.
Old Mar 27, 2012 | 08:10 PM
f1501987's Avatar
f1501987
Yea, the truck runs fine still, it just goes rough running when I idle down while driving.then back to normal
Old Mar 27, 2012 | 08:12 PM
f1501987's Avatar
f1501987
No other codes on my edge insight. Also can u define what cps,uvch means
Old Mar 27, 2012 | 08:17 PM
fordpride's Avatar
fordpride
Camshaft position sensor= CPS
Under valve cover harness = UVCH
Old Mar 27, 2012 | 08:20 PM
f1501987's Avatar
f1501987
So the cps is at the front bttm of the motor right?
Old Mar 27, 2012 | 08:25 PM
F350-6's Avatar
F350-6
Yes. It's the sensor that has the thing that looks like the timing mark at the crank.
Different year motor, but this shows how to change it. Welcome to guzzle's CPS R&R Web Page<
Should be around $25 or so from the Ford house.
Old Mar 27, 2012 | 08:30 PM
f1501987's Avatar
f1501987
Ok,ill try to get one tommaro, then I'll update ya. What would burnt pins take to fix?
Old Mar 27, 2012 | 08:41 PM
fordpride's Avatar
fordpride
New valve cover gasket set
Old Mar 29, 2012 | 05:41 AM
f1501987's Avatar
f1501987
Also what you mean by its time to walk? Just more than likley your going to be walking? Or time to trade in?
Old Mar 29, 2012 | 04:58 PM
f1501987's Avatar
f1501987
Well replace my cps, drove it to work 20 mins away, no problems. Hope this fixed it.
Old Mar 29, 2012 | 05:42 PM
fordpride's Avatar
fordpride
Good deal. Normally when a CPS dies your walking home are calling a buddy
Old Mar 29, 2012 | 07:58 PM
F350-6's Avatar
F350-6
When the CPS goes, or becomes intermittent, the computer can no longer read the timing of the engine so it doesn't know when to fire the injectors. Rather than destroying the engine due to improperly timed injection events, the computer simply shuts the injectors down and won't allow any of them to fire. That means coast to the side and start walking or call for a ride.
A $30 sensor is hardly a reason to trade the truck in. (unless you want to make me a good deal on yours ) The only CPS failure I've had on my current truck happened around 155,000 miles on the odometer. I've over 398,000 now. No reason at all to trade the truck in.
Old Mar 30, 2012 | 05:58 AM
f1501987's Avatar
f1501987
Good deal thanks for the help
tsmall07
20
Jan 15, 2019 11:35 AM
4inchlovin
13
Jan 21, 2009 07:14 PM
IM1096
Mar 29, 2007 09:02 PM
99f250
Jul 25, 2003 12:47 AM
