bed to frame fasteners
Old Mar 27, 2012 | 05:16 PM
2Hick's Avatar
2Hick
I purchased a polyurethane body mount kit for my truck and they appear to be thicker than the stock ones. I am worried that the bed won't line up with body lines when I put it all back together. Has anyone else experienced this and what did you do? Also, I can order the bed mount hardware kit but it looks like I can just purchase the parts from my local hardware store, what nuts and bolts do I need?
Old Mar 27, 2012 | 11:30 PM
jhooch's Avatar
jhooch
I just used carriage bolts on mine. The stock mounts usually squash down over time, the poly mounts usually fix the problem.
Old Mar 27, 2012 | 11:47 PM
garbz2's Avatar
garbz2
Carriage bolts a 7/16 18. Hardware store carrige bolts will have a smaller head the the stock bolt.
Were did you find a poly mount kit for 65 66?
Garbz
Old Mar 28, 2012 | 10:05 PM
Customcab's Avatar
Customcab
Don't forget the two hex head bolts under the bed along back of frame; at the end of the frame rails as well. Should the poly bushing be about the same height as the factory bushing; if a little taller use flat washer between bottom of bed and top of frame to achieve same height. also don't forget the radiator support ones as well.
Old Mar 29, 2012 | 07:24 PM
2Hick's Avatar
2Hick
Garbz2, the poly mount kit came from Prothane
The_Scatch
May 27, 2019 10:32 AM
yargnitram
Oct 9, 2016 08:53 AM
learpilot
Dec 28, 2005 03:44 PM
crazy_goodolboy
Aug 9, 2001 09:35 PM
boomer99
Jul 11, 2001 04:55 PM
