tip for fuel gauge not working :-)
ok so went back to my truck and followed the wire that came from my fuel tank too the dash.from the picture you can see, the arrow without txt from what i was able to follow is the same wire from the fuel tank after it goes through elctrical tape.
however it is cut here.
now what i am wondering now is the green/yellow wires are supposed to be fuse to courtesy lamp switch, what would happen if i was to connect the cut wire with the two green/yellow to single red wire? dont want to melt or start a fire
what i would do is splice both cut ends together, orange to orange. you could hit one of the green wires, but if you ever need to disconnect you can just unplug the boot if you stick with the orange. i would take a pair of crimps or something you can crimp with and use a connector to put the two red/orange wire ends together.
ref your pic, my orange wire goes up & over the door frame then comes out under the dash and goes into the fuse box, just before the fuse it splits & goes to the gauge selector switch, on my truck it sits under the dash below the headlight switch & ignition switch, hope that helps you out..
drizzie27: The floor switch is to physically switch which tank is getting drained. The switch under the dash is for the gauge (to show what's in a particular tank, but not necessarily indicate which tank is the active tank).
Clear like mud, right?????
72RichB: I feel your pain, man...
so the sending unit wire is hooked straight to the gauge? if thats the case, the easiest thing to check is the sending unit first. take it out of the tank and disconnect the wires. if you put an ohm meter to it it should read around 73 ohms empty and around 7-10 ohms when full. if you get these readings then your sending unit is good and your gauge is shot. imho i would just get an after market gauge and cup from autometer, 73-10 ohm, and put that in your truck. my gauge didn't work and i could not for the life of me find anyway to replace the original gauge without replacing the entire instrument panel, which was a lot more money and time than just getting a $43 dollar gauge and is a very easy install.
I have a problem to ad to this thread.
The pervious owner pulled the tank out of the cab in my 72 f250 before I bought it. The fuel gauge didn't work at all, always on E. So I traced the wires from the aux/main tank switch and noticed that the wiring was just in a jumbled mess. So I found the orange wire coming from the tank under the bed and connected it to the orange wire in the main wiring harness under the dash. Now the gauge reads half a tank when I start the truck but never moves.
Any thoughts, advice?
Pull the wire at the bed tank sending unit and ground it...if gauge is good it will peg over to full with that wire grounded. Then pull the sending unit, check float and clean the inside of the unit...the resistance card in there gets grimey, clean it with carb cleaner to get the contacts clean.
learnt the hard way if your fuel gauge doesn't read anything and you no longer have the auxiliray tank, flick the switch on the dash!!!! mine's been OS for a couple of weeks & was tracing the wire in case I needed to change the wire & add an inline fuse, followed the wire & found a spur to the switch, that's when I had a "DOH" moment, gauge now works fine laughed for 5 mins......
#29
Tartersauce53
07-24-2017 08:18 AM
Erictusio
02-13-2017 12:58 AM
RacinNdrummin
04-01-2013 03:07 PM
