Volt help?
Old Mar 26, 2012 | 12:14 PM
PSD2005's Avatar
PSD2005
Volt help?
05 with 107k on her! My gauge was reading 11.8 in the morning before I started her up! With the glow plugs on and starting her, it would drop all the way down to 11.1! When the alt. Would start to come on it would jump up to 12.7, then all the way on it would be 13.7! I put bran new Moro craft Batteries now I'm at 12.4 in the morning, but when I started her up it drop all the way down to 11.1-11.5! But would only stay there for a little wile, then it would be 11.9-12.2!! What the heck is going on here? 11.1?????? With new batteries
Old Mar 26, 2012 | 12:51 PM
69cj's Avatar
69cj
That's the glow plugs pulling the voltage down and then the starter kicks in. Your voltages look normal. When the glow plugs time out, 1 to 2 min, that's when your voltages jumps back up. You look good to go. Optimal voltage in the morning before turning the key should be 12.5 to 12.7 volts.
Old Mar 26, 2012 | 02:08 PM
PSD2005's Avatar
PSD2005
Thanks Brother!!! I new when I got up in the mornings and my volts were 11.8, it scared me don't what to burn up a FICM! That's why I bought new batteries now I'm 12.4 in the mornings fell a lot better!!! Plus I have 850 cca
Old Mar 26, 2012 | 03:07 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have you purchased a Scan Gauge yet? If not, it's highly recommended. Enables you to watch the FIMC voltages as well as the coolant and oil temps. Very critical!
Old Mar 26, 2012 | 03:17 PM
PSD2005's Avatar
PSD2005
Yea that's I new the volts were low! That's
Old Mar 26, 2012 | 05:20 PM
dchamberlain's Avatar
dchamberlain
What is your voltage at idle after the truck has been running for a few minutes?
Old Mar 26, 2012 | 08:12 PM
PSD2005's Avatar
PSD2005
13.7-13.9!!!!!
Old Mar 26, 2012 | 08:18 PM
dchamberlain
OK. That's fine.
bismic's Avatar
bismic
Doesn't sound bad to me.
Walleye Hunter
42
Feb 1, 2019 01:43 PM
Jtpadilla1030
Jul 25, 2018 08:19 AM
1985L8000cat3208
Feb 1, 2016 08:38 AM
JTyler11688
Jun 24, 2009 09:27 PM
F0rdF0rever
Apr 2, 2004 04:15 PM
