Sponsored by: Kumho
Can I Improve breaking performance
Old Mar 24, 2012 | 11:10 PM
Thesteeleboy's Avatar
Thesteeleboy
I have two 1977 F-150 4x4's. They both have 4" lift and 35" tires. How can I improve my breaking performance on these truck's. they have new callipers, pad's and rotors but just don't have the break power to hold the truck back on extreme grades while rock climbing.
Old Mar 25, 2012 | 08:17 AM
garypettengill's Avatar
garypettengill
Good loking truck, keep up the fun. Getting better brakes on these trucks is covered by an article in the technical section on upgraking brakes on a Bronco, same system. Things that I can add as I have upgraded my '77 are as follows:
Stay with the alumnimum wheels if at all possible, much less rotating mass compared to steel.
Change out all the flexible lines with new, high quality, stainless lteel braided lines in the brake system. The old ones start to expand under pressure when they get older.
EBC brakes pads are an option, although I haven't installed them on my truck.
I did the whole program with the F350 booster, Thunder Bird calipers and F350 rear cylinders. I think I went back to the F150 rear cylinders because I had way too much braking on my rear end. ALWAYS locking up the rear tires.
I purchased most of my parts through RockAuto.com and was able to save a bunch there because of lack of core charges. You can't trade in and F150 booster in a F350 box, the rebuilder will catch it and then your parts store will be looking for you.
The biggest issue in the whole change over was mating the front brake lines to the Thunder Bird calipers. They use a different type of hookup at the caliper versus the truck.
Old Jul 23, 2021 | 09:52 AM
Aftrmidnite's Avatar
Aftrmidnite
I second the Braided Flex Hoses. I tried a lot of different things on my 2001, to increase the braking power, and pedal feel. I even went with the Expensive “Cheese Graters,” what a mistake that was. Just make sure they are DOT Rated. Mine are Russell’s.
J ballan
22
Dec 19, 2017 07:17 PM
Dave145
16
Nov 24, 2016 08:59 PM
LittleRadio
Aug 10, 2015 01:55 AM
RRranch
22
Jul 25, 2011 12:36 AM
400ford
Aug 11, 2006 11:07 PM
