Hey i disabled my linkage because it was the cause of my late shifts. Is this safe?
There are several people on the board who have said that they took their linkage off for various reasons. I don't think it is a safety issue unless you pull out into traffic and want it to down shift automatically, or pass a car. Are you sure that was your problem? Try posting your problem and see what comes up. I bet someone else has had your exact same problem. Good luck!
Ive posted it on several different sites, mainly no answers. I just want it to shift when its suppose to and not burn up my gears. It shifts smooth like no ones business now. 20 then 30-35 instead of 30 then 50 which is DEFIANTLY WRONG.
I am not worried about passing... I can do that with it off lol
I have had a C6 in my truck since 1980 with no down shift rod, if I nail it @ 15to20 it drops to 1st gear. Under normal driving it up shifts @ 8 and 15. Has a 3.50 axle. Kenny
I'm not sure what axle is in it... but its good to verify that its safe.
I recently had to put it back on turns out its the way the bracket was built on the orginal 2 barrel i had to bend the bracket that has the screw in it to a different angle in order for the kick down to work properly. now there is space for it to throttle and space enough for it to kick down when i mash on the gas.
