Lokar shift linkage and a C-6
on
trying to check off a 'thing' on my list started to install shift linkage from column to c-5
Instructions say it might be necessary to cut off the original shift lever and install theirs.... here's what I got
anyone use this linkage with a c-6... little help ?? don't want to go choppin things off before I know what I'm doing (hmmm, that might take a while)
j
j
Received 4,132 Likes
on
This what my C6 looks like. The shift lever was already removed when I got it. I had to move the shifter back and make a new rod (it was too far forward with a really short rod and binding) . They say to make the rod straight but it works with a bend in it too.
I also cleaned it after this...
My C-6 Lokar installation looks like the one directly above, except I used a straight rod.
Note the shift lever must be installed to rear of the lever on the transmission in order for
there to be enough travel to engage all the gears. On my first installation attempt, I tried
install the Lokar forward of the shift lever on the transmission and that does not work.
on
What type of shifter do you have John.? Is it cable operated or trans mounts?
http://lokar.com/assets/instructions...ed-Shifter.pdf
http://lokar.com/assets/instructions...untShifter.pdf
on
column shift, John using Lokar shift linkage kit... rod and heim joints connect column end to trans shift bracket.
Cat28_1030
no cables... just hard linkage.
Cat28_1030
on
Cat28_1030
Cat28_1030
on
well I've pranked with it most of the day trying to get the linkage working properly. The C-6 has (in order top to bottom) P R N D L2 L and I couldn't get it to recognize L2 and L. There was a detent on the Ididit column for PRND and then one more. Frustrating since I' working alone and the up/down is killing me...
so I called Ididit wondering if they configured my column for 1-Reverse and 2Forward. Tech told me that they only detent one time after D and I should just find where L2 engages on the transmission... would have been nice to know that ahead of time !!!!
do you see any possible problem with that
so I guess I'll set the lowest column shifter position for low (furthest travel on the trans lever and just feel for L2...
do you have that same situation with your cable linkage ???
j
j
on
I can't remember to tell you the truth if I felt the detent in second or not but I seldom had it in low either other than when I set the sending unit to let you know what gear you were in. The shifter locked in park and neutral..I'm using the same shifter for my AOD and can go out and check. The AOD even though has an extra gear only has OD D L
on
j
j
