Did the main seal
Old Mar 24, 2012 | 06:47 PM
diablodude64's Avatar
diablodude64
Did the main seal
I did the rear main seal with the kit from the stealership and so far no leaks. Everything was pretty smooth, other then smashing my finger between the large chunk of steal known as the block and the hammer I was using... still fricken hurts and is about twice the size as the other.
Anyways, after screwing with that for a bit, I decided to ream the install tool to use the flywheel bolts. That worked beautifully and the seal went right in.
Resealed the pan gasket and the transfer-case and so far, I have no loss of oil, and not a drop of leaking fluid anywhere. Fingers crossed.
Thanks, Kyle
Old Mar 24, 2012 | 07:16 PM
monte97z's Avatar
monte97z
Very nice Congrats
Old Mar 26, 2012 | 08:30 PM
diablodude64
Here are a few pictures, as I know everyone loves pictures!
That thing sits in there pretty far!
Old Mar 26, 2012 | 10:25 PM
joshofalltrades's Avatar
joshofalltrades
looking at how deep it sits in there makes me think that if someone ever has seal problems as a result of shaft wear, you should be able to have the seal out 1/8" from where it is and solve that problem easily
i hope you lubed the sealing lip of that seal when you installed it
Old Mar 26, 2012 | 10:31 PM
diablodude64
I used aviation sealant #3 as per the instruction. It said not to lube anything.
~Kyle
Old Mar 26, 2012 | 10:43 PM
joshofalltrades
ok, on every seal i've installed in various applications, its advised to lube the lip that rides against the shaft, otherwise the initial break-in period will cause the rubber to be damaged by the shaft. but i would trust the manufacturer if they said not to
Old Mar 26, 2012 | 10:51 PM
diablodude64
I would agree with you, but so far no leaks.
Old Mar 27, 2012 | 01:21 AM
joshofalltrades
since you have to speak of this seal, i found myself under my van a few minutes ago looking at something else, and noticed that my rear main seal is leaking too. it'll probably wait till next year.
since you posted about yours, mine must be your fault
Fefanatic
6.4L Power Stroke Diesel
Apr 13, 2019 05:00 PM
bruno2
Feb 4, 2018 02:37 PM
2020
Nov 23, 2012 08:25 PM
Cooper24
Modular V10 (6.8l)
Jul 13, 2011 08:36 PM
