Turn signal problems/ needs fixed ASAP!!
Old Mar 24, 2012 | 02:37 PM
NW 150's Avatar
NW 150
My 75 f100 has problems with the turn signals:
  1. The front signals do nothing.
  2. The rear signals work from time to time, but have a sporadic pulse and are not very bright when they do work.
  3. If I press the brake pedal and select the left signal, that brake light will go out and do nothing, and won't come back on until I turn off the signal. Same goes for the other side.
I need to know where/what to look at, what I should replace, etc. This needs to be fixed ASAP or obviously I can't drive it, and that's not acceptable.
Old Mar 24, 2012 | 03:50 PM
devino246's Avatar
devino246
Check your grounds with a multi-meter or test light.
Old Mar 24, 2012 | 06:00 PM
NW 150's Avatar
NW 150
I Sanded down all of the ground connections and covered them with electrical grease and they worked again. The only problem that remains is that when the parking lights are on, the blink of the turn signals are so faint that it's pointless to even use them. If the parking lights are off though, the blinks are as bright as they will ever need to be for someone to see them. Any suggestions?
Old Mar 24, 2012 | 07:14 PM
fmc400's Avatar
fmc400
MSEE
This means it's time to replace the sockets.
Old Mar 24, 2012 | 11:07 PM
NW 150's Avatar
NW 150
So just get two new ones and cut/connect the wires and that should fix it?
Old Mar 25, 2012 | 11:56 AM
Ohiocrewcab's Avatar
Ohiocrewcab
You might want to make sure everything is connected right when yo put the new sockets in. I had an issue with my old 77 that the p.o. wired it wrong and the parking lights were comming on as the bright side of the bulb and the turn signals were the dim side. You couldnt see them at all at night.
Old Mar 25, 2012 | 01:05 PM
NW 150's Avatar
NW 150
I'll have to look into that, although none of the wires have ever been switched, all are the same color going to the same color wire.
jommer
Electrical Systems/Wiring
Aug 13, 2005 09:50 PM
rogue s.
Feb 6, 2004 05:52 PM
btnbronc
Jan 28, 2004 11:52 PM
pigfanatic
Aug 27, 2002 12:01 PM
