idle controller
Old Apr 28, 2003 | 08:54 PM
wyldbillracer's Avatar
wyldbillracer
idle controller
my truck idles for extended periods, I have looked around and found that i may need an idle controller to makeit idle up, plus driving outwest and stuck in traffic that has come to a stop and would like to idle it up so the ac will stay cool and not built too much head pressure in the a/c system, my question is where can i find a ilde controller? thanks for any info.
Old Apr 28, 2003 | 09:59 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
idle controller
You can get the big ugly factory one from ford for $300-400, or you can get an aftermarket one for a little over $100 or you can build your own (the option I chose) for less than $10.
Old Apr 28, 2003 | 10:50 PM
theologian's Avatar
theologian
idle controller
Will your AIC concept work with the 1996 trucks, or just for the newer ones?
Old Apr 28, 2003 | 11:36 PM
1997 crewcab's Avatar
1997 crewcab
idle controller
http://www.northtexaspowerstrokes.com/mods/aic/
try this for the '96
Old Apr 29, 2003 | 06:59 AM
powerstroker250's Avatar
powerstroker250
idle controller
I have one, you can see it in my pics.
Les
Old Apr 29, 2003 | 09:22 AM
theologian's Avatar
theologian
idle controller
Thank you. This is the most comprehensive set of instructions I have ever seen - So well presented even I can generate confidence to cut wires..
I will get the bits, and let you all know.
Theo
Old Apr 29, 2003 | 01:57 PM
wyldbillracer
idle controller
Thanks for the info, i will be putting this together in a few weeks.
Very good info.
Old Apr 29, 2003 | 06:30 PM
Hurricane_Niner7's Avatar
Hurricane_Niner7
idle controller
Hello,
Would there be any adverse affects on my engine if I start my truck with an AIC engaged?
I have a 3rd battery installed in my toolbox to run a power inverter. I use the timer function on my remote start system to start the truck to keep that 3rd battery charged up. When running at an idle, it doesn't charge fast enough. Will it hurt my engine to start it with the AIC engaged to charge the battery faster. I know it won't be a super change in charging time but every little bit helps.
Thanks,
1LT Anthony Somma
My Daily Driver an steroids:
'03 Oxford White F-250 XL 7.3L PSD, CC, LWB, 4x4
Old Apr 30, 2003 | 05:03 AM
alanscott's Avatar
alanscott
idle controller
The AIC availible from Ford has a delay before it idles up the engine, about 5 seconds or so. I don't know about the others.
Old Apr 30, 2003 | 06:50 AM
powerstroker250
idle controller
The CTI idle controller that I have is turned on and set manually, not by the pcm.
Les
Old Apr 30, 2003 | 11:50 AM
cookie88's Avatar
cookie88
FTE Emeritus
idle controller
It will smoke like a freight train while it's starting up, but won't hurt anything, as long as you don't have it set so high the CP's (cylinder pressures) go crazy. 1100-1200 rpm won't hurt anything.
8kgold69
Sep 10, 2016 12:43 PM
Brian Young II
Escape & Escape Hybrid
Jul 23, 2016 08:45 AM
landmime
17
Sep 19, 2013 02:20 PM
69deville
3.8 & 4.2L V6
Apr 10, 2007 03:46 AM
Jrock909
Oct 24, 2004 11:37 PM
