will not start
Old Mar 23, 2012 | 06:56 PM
josephwallace's Avatar
josephwallace
will not start
oK I decide to change my oil and my feul filters.DID RESEARCH.and did it ,so i went to crank and it wouldnt.
AFTER INSTALLING FILTERS changed the orings and lubed them and tighten them up
Then I turned the switch 5 times to the on position and then attempted to crank it and it will not crank,so I checked my fuses,reset feul switch and then removed the top filter and added more feul and had my nephew turn the key to the on position while i watched the top filter and it was bubbling we repested til it stoped then re-assembled and tried to start it again and no start can anyone help me
joseph
Old Mar 23, 2012 | 07:07 PM
bismic's Avatar
bismic
Are you saying the engine does not turn over at all? That is what "does not crank" means to me.
Old Mar 23, 2012 | 07:08 PM
josephwallace
it wil not start it tries but no start
Old Mar 23, 2012 | 07:13 PM
BLADE35's Avatar
BLADE35
Sounds like the wrong oil cap/Filter combo
Old Mar 23, 2012 | 07:23 PM
BLADE35's Avatar
BLADE35
So you have air Bubbles in the Upper engine mounted fuel Filter
If so its sucking air somewhere from a Pinched or Nicked Oring Down on the HFCM the fuel pump housing on the frame Where that filter is
Did you lube these Oring with Clean Oil B4 Install???????
bulldog88
22
Feb 14, 2015 03:34 PM
Scooter7227
Sep 17, 2011 11:34 PM
oldkountryboy
16
Aug 22, 2010 12:01 AM
Lubbockguy1979
May 11, 2009 09:05 PM
hosoria
Apr 21, 2009 04:30 PM
