Latest Strategy
Old Mar 23, 2012 | 05:17 PM
bansheemike's Avatar
bansheemike
Latest Strategy
Just had the latest strategy programed on my 06' this morning.
VXCF5H5
TQCK0HZ
Any comments?
Old Mar 23, 2012 | 06:18 PM
cheezit's Avatar
cheezit
ya thats no tthe latist on an 06 should be vxcf9 ?? the last 2 number can change.
Old Mar 23, 2012 | 09:22 PM
bansheemike
Thanks cheezit. Back to the dealer on monday.
Old Mar 23, 2012 | 10:32 PM
Rob_in_Alberta's Avatar
Rob_in_Alberta
how does one tell which flash is running? is there a way to read this information off of the pcm?
Old Mar 23, 2012 | 10:41 PM
cheezit's Avatar
cheezit
yes a quality scan tool.
cheezit's Avatar
cheezit
have the dealer show you which update of ids he is using. they should be on 74 or later (iirc)
Old Mar 24, 2012 | 08:45 AM
kidoo's Avatar
kidoo
When was the latest flash released? I think mine is stock, i never heard any dealer reflashing my truck. Any advantage having the latest flash?
Old Mar 24, 2012 | 11:34 PM
Rob_in_Alberta
cheezit - is scan gauge capable?
Old Mar 24, 2012 | 11:43 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Don't ref lash it!!!!!!!
You'll lose MPG and HP
THE NEWER FORD FLASHES SUCK!
Many guys are rolling back their flashes to early 03 strategies for fuel economy and power. The only reason I can see getting a newer flash is to have the inductive heating for injectors. Even then, I would seriously consider not doing it if the truck runs fine when cold outside
Old Mar 24, 2012 | 11:54 PM
Unrealo4's Avatar
Unrealo4
Lol just noticed tylus's avatar. Army of the dead ftw!
Old Mar 25, 2012 | 01:38 PM
cheezit's Avatar
cheezit
dont know about scangauge. I dont think so. sct tuner will
Old Mar 25, 2012 | 01:59 PM
npccpartsman's Avatar
npccpartsman
I wouldn't go to the VXCF9. The tuners say 4 or 5 is much better. It would actually be nice to know what the FICM strategy is. That's much more important.
Old Mar 25, 2012 | 02:05 PM
John Irwin's Avatar
John Irwin
I had mine reflashed, and it's never been the same for power or mileage, but it runs great when it's cold, the latest flash is supposed to be easier on the ficm as it doesn't use the inductive heat as much. It also is supposed to turn the wrench light on if eot/ect delta's excede 15 degrees. I think there's less chance of lifting the heads too...mine won't go near 30psi now, although I'm sure they never did the vgt relearn, I'm going to do it myself in the next little while.
Tylus, how do you roll back to the older flash, I thought once you upgraded you couldn't go back?
Old Mar 25, 2012 | 04:01 PM
kidoo's Avatar
kidoo
Even if you did not have a reflash, would it be a good idea to do a VGT relearn?
Old Mar 25, 2012 | 04:14 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Bill @ Power Hungry Performance does it. It's my next mod. He rolls back the PCM to an earlier strategy
He also offers custom FICM strategy. On the Nation he has a thread right now showing amazing gains and increased drive ability.
I know 1-2 other tuners can roll you back. Just can't remember their names
derek witt
Jul 27, 2006 09:45 PM
Chipmm
Car/truck Buying Advice
Aug 2, 2005 01:35 AM
kenwowski
Feb 14, 2005 01:17 PM
