Need help with leaf spring selection
Old Mar 23, 2012 | 09:12 AM
IowanStraight6's Avatar
IowanStraight6
So I put new 844 moog coils and gas magnums in the front. Now the front sits a little taller than the rear bout half an inch. The leaf springs are wore out. The left one sags worse than the right so the body lines off, I'm guessing because of the dual tanks. So I have two options from rock auto. #1 UCF Part # 43689 Rear; 4WD; 3/1 = 4 Leaf, 1 9/16" Pack Thickness, 1700lb Per Spring Rating. or #2 UCF Part # 43695 Rear; 4WD; HD Use Only; Will Raise Rear of 1/2 Ton 2" to 3" From Stock Height; 4/1 = 5Leaf; 2" Pack Thickness; 2450lb Per Spring Rating. Which one do you guys think will give me a rake of 1 1/2 to 2 inches. The trucks a 96 f150 sclb 4x4 thanks in advance!!
Old Mar 23, 2012 | 10:38 AM
GNR22's Avatar
GNR22
I'm willing to bet that the "HD Use Only" springs will ride like a 3/4 ton. And the #1 is probably more stock height. If you won't mind the rough ride, get the 2nd one.
Old Mar 23, 2012 | 10:44 AM
IowanStraight6
I don't mind rough at all I'm just wondering since one ton coils are in front which one would give me that slight rake I'm looking for
Old Mar 23, 2012 | 07:03 PM
IowanStraight6
Bump anyone
johnson.jeff.a
Aug 22, 2016 04:24 PM
TheTowingCowboy
Apr 1, 2011 10:40 PM
buck_
1978 - 1996 Big Bronco
Oct 26, 2010 11:40 PM
bucci
May 3, 2010 01:33 PM
QuickerPickerUpper
Jul 12, 2003 09:21 AM
