Help please
I just converted from vac to hydroboost hooked the lines no master cyl change and the brakes are now draging I removed the master cyl from the hydroboost and started the engine and the shalf comes out to apply the brakes with out touching the brake pedal
I have checked other conversion's forums to see if I stuffed up the hoses but they are all ok
so what can the problem be
