Sponsored by: Real Truck
trailer wire problem
Old Oct 7, 2007 | 05:26 PM
jbrianas's Avatar
jbrianas
my right trailer stop light has been stuck on for a couple weeks now.
when i disconnect trailer from truck, there is still power in the
trucks trailer connector, with truck on or off.
its 05 f350 with tow command
any ideas what to do?
thanks
Old Oct 7, 2007 | 06:37 PM
rusbukt's Avatar
rusbukt
Do all of the other lights work as should ? Are you using a factory installed trailer connecter ? Have you added any other accessories to your truck ? Cant imagine how all of sudden you got constant power to only one brake light. I could see it if they were both staying on.(Brake light switch) Does the left brake light work as should? good luck.
Old Oct 7, 2007 | 06:47 PM
Help I M Stuck's Avatar
Help I M Stuck
check to see if your trailer connecter left dirt inside the connector on the truck..then try replacing the light bulb.
Old Oct 7, 2007 | 07:04 PM
F350-6's Avatar
F350-6
Welcome to the site.
Which type of plug are you using? The brown wire should control the running lights, and yellow and green control the turn. A combination controls your brake lights. The plug on the back of the truck will have power to it whether a trailer is hooked up of not.
If you want to isolate the problem trying hooking up to a different trailer, or have someone else hook up to your trailer and see if the problem is duplicated. If you can't do that you could always switch the position of the yellow & green wire so and see if the problem shows up in your left signal.
Old Oct 7, 2007 | 09:14 PM
flyinnuts's Avatar
flyinnuts
F350-6 is correct in that the plug will have power on it at all times IF a turn, brake, running lamp are selected in the cab. with truck off and no lights or brakes i dont think there should be any power to the plug. the only power to the plugs on my 04 with tow package is trailer power with truck running. 04 wire bundle comes from rear of truck along frame rail up into the engine compartment below master cylinder to a connector. from there thru the firwall to inside truck. disconnect under the hood and check for voltage.
sorry i dont have a diagram of an 05 and i am not familiar with tow command. are there any relays in fuse block dealing with trailer brakes? if so pull it and see what happens.
good luck
Old Oct 7, 2007 | 11:02 PM
jbrianas's Avatar
jbrianas
everything has worked fine for 2 years now with the same truck and
trailer, the trailer lights work fine on my other truck. so its narrowed down to
the f350. all the other lights work fine, just the right side stop light is stuck on all the time while connected to the truck. I have already checked the two connectors on the truck and they are both clean and corrosion free.
how do you reset the tow command system? or is that even possible?
thanks
Josh
It has to go in for a leaking front axle , so i guess ill have the dealer check it out then, just sux cause i trailer every day.
Old Oct 7, 2007 | 11:10 PM
G BOBKA's Avatar
G BOBKA
I have the same problem on my 2000 F350 what's up with that. I hope I can catch the next thread. So I can figure out what's wrong with mine.
Old Oct 7, 2007 | 11:34 PM
flyinnuts's Avatar
flyinnuts
is there a relay for your tow command? cb? and i agree if you are unhooked from trailer and getting voltage on the right turn/brake with truck not running it is a truck fault. r u using the 7 way or 4 way plug?
Old Oct 7, 2007 | 11:40 PM
G BOBKA's Avatar
G BOBKA
I have tried both plugs, a small trailer type and a big round one. And I still have the same problem. Is it a relay? I don't know at this point.
Old Oct 8, 2007 | 06:24 AM
jbrianas's Avatar
jbrianas
i use the big round seven pin plug
I checked both plugs with a multimeter and
both have constant power on that wire.( i think there piggybacked anyway)
good idea on the relay, i looked in the owners manual and couldnt find anything
about any relays. but maybe ill just start pulling them out from under hood , one at a time and give each one a couple taps and retry it.
thanks
Josh
Old Oct 8, 2007 | 08:25 AM
flyinnuts's Avatar
flyinnuts
again i am not so sure on your year truck, but you have some relays in the fuse block and under the hood and and on my 04 there are what ford calls "unserviceable" relays which seem to be intergral to the central junction bofuse panel). then there are a few relays under the dash that you wont find in the manual.
pull relays and then check voltage.
and yes both plugs are feed from the same harness, which comes from the connector under the hood on the drivers fender well. i would find that connector on your truck, disconnect it and see if voltage is present at the plug. this rules out a short from the firwall back.
you might want to place this thread in the electrical /wiring problems a little further down the forum page. maybe someone there has a wiring diagram for your truck and could tell us where the right turn/brake get power.
Old Oct 8, 2007 | 08:46 AM
jbrianas's Avatar
jbrianas
thanks for the help,
ill post back this afternoon after i tinker
with it some
Old Oct 8, 2007 | 04:43 PM
jbrianas's Avatar
jbrianas
i think i traced it to a sticky relay under the hood. seems when the truck heats up under the hood it starts to stick. so i swapped the relays for the right and left
side trailer lights. so ill see if the other side sticks on tomorrow.
thanks
Josh
Old Oct 11, 2007 | 08:05 PM
jbrianas's Avatar
jbrianas
yup, now left side trailer light is stuck on
problem solved
thanks
for the help
Old Oct 11, 2007 | 10:23 PM
flyinnuts's Avatar
flyinnuts
Good deal. glad we could help.
Bryan
