All wrapped up...
Old Mar 21, 2012 | 08:37 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
All wrapped up...
My brother and I just wrapped up the work we were doing on his 05 6.0. It runs like a champ now. Before he was experiencing what we feel was injector stiction. It took a while before it would kick off, but when it did there was an immediate improvement to the sound at idle. I now have 2 of these jobs under my belt, just adding the injectors to the list. Again, not possible without you all! Special thanks to Blade35, Cheezit, and M-Chan for advice on the injector cups...
Oil Cooler - just because we were that deep
STC Fitting -
IPR screen -
Standpipes -
Dummy plugs -
8 Injectors -
Injector harness -
8 glow plugs -
Glow plug harness -
Water pump -
EGR Delete - Welded factory EGR cooler. EGR is still in place and plugged in.
Oil filter standpipe - Not by choice, little plastic piece broke...
Battery cable harness - Entire harness from drivers side battery to the starter...
Old Mar 24, 2012 | 03:43 AM
garndog's Avatar
garndog
EGR is still in place and plugged in. about this.. i have a EGR delete also and have no tuner... i get the engine light .. can i put the Valve back in and plugged up and get rid of the light??? thanks been looking for this,
Old Mar 24, 2012 | 06:41 AM
2006powerstroke90's Avatar
2006powerstroke90
The light will still probably be on due to no EGR flow to the valve.
Old Mar 24, 2012 | 07:12 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's on of many good threads on the subject:
https://www.ford-trucks.com/forums/1...fications.html
Old Mar 28, 2012 | 08:57 AM
garndog's Avatar
garndog
ok thanks!! i can live with the check engine light until i get my tuner..
Old Mar 28, 2012 | 09:17 AM
Crash16's Avatar
Crash16
Will the fan still work without the EGR valve? I left mine in and plugged in when I did my delete. No CEL.
Old Mar 28, 2012 | 09:31 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
It is my understanding by leaving the EGR valve unplugged it affects the fan speed. So an over heat scenario may occur.
If I am wrong, someone can jump in and save me...
Old Mar 28, 2012 | 09:40 AM
garndog's Avatar
garndog
i have mine plugged in and tie warped secure under the hood.
Old Mar 28, 2012 | 10:06 AM
Crash16's Avatar
Crash16
I remember a post bismic posted about this. I would include it if I wasn't on here through my phone.
Old Mar 28, 2012 | 10:12 AM
Crash16's Avatar
Crash16
Search for "side effects of disconnecting EGR valve" and it was cheezit, sorry. Not trying to give away anyone's credit.
Old Mar 28, 2012 | 11:11 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
You are correct.
Old Mar 28, 2012 | 12:26 PM
Snuggyworm's Avatar
Snuggyworm
if egr valve is disconnected, the fan will not work. tats jus plain old creating more problems, y'all.
jayc3169
Feb 9, 2015 10:17 AM
kel1306
Apr 4, 2011 05:37 PM
sammy77
Nov 2, 2010 05:55 AM
motor-man
Feb 24, 2010 04:06 PM
Densue
Dec 7, 2007 06:48 PM
