aftermarket headlights
Old May 1, 2012 | 10:10 PM
OldStyle's Avatar
OldStyle
Rusty Roller
The above link still works for me.
Old May 1, 2012 | 10:13 PM
PRIMERED79 SHORT BED's Avatar
The links inside the link lol.
Old May 1, 2012 | 10:38 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Only found 2 links down near the bottom of the page and those 2 didn't work.
Are you seeing the diagrams?
Old May 1, 2012 | 10:51 PM
Are the diagrams what the links lead to?
I was just curious about the high/low light on at the same time diagram.
Old May 1, 2012 | 11:03 PM
OldStyle's Avatar
OldStyle
Rusty Roller
I'm a little brain dead at the moment but the 2nd diagram's green optional wiring shows how that is done.
The 2 links are dead so I don't know what they showed.... ie: (stocwire_1.jpg and newwire_1jpg)
I have seen other posts about these setups but can't find them right now....
Old May 2, 2012 | 01:22 AM
351M's Avatar
351M
Can't have hi and low on at once unless you have 4 headlights or it will burn them out fast. (Think '96ish Chev Pickup)
Old May 2, 2012 | 08:01 PM
Is that due to heat build up or something?
Old May 2, 2012 | 08:17 PM
351M's Avatar
351M
I think so yeah.
Old May 2, 2012 | 10:59 PM
jgavac's Avatar
jgavac
Just thought I'd share a couple pictures of side by side lights of different types.
This is a 6000K HID (Passenger side) next to a 125W output "Euro" Style H4 bulb (drivers side), which is supposed to be 6000K like the HID bulb. The Euro style bulb is just a bright halogen with a light blue coating on the outside to change the kelvin tint to the light.
And this is a stock sealed beam halogen (Passenger side) next to the same 6000K HID bulb in the last picture.
Both times I metered the light off the HID bulb.
-Jameson
Old May 3, 2012 | 01:01 PM
AK Adventurer's Avatar
AK Adventurer
Did you change any wiring harness to run the HIDs, or just change to lens units to hold hem?
G.
Old May 3, 2012 | 11:40 PM
jgavac's Avatar
jgavac
G.
No changes to the stock wiring harness. H4 bulbs plug directly in. The only thing with HID is the incorporation of the ballasts. The wiring is easy; Attach the positive lead to the battery, the negative to the body, and then run the wires across the front to the other side, and plug them in.
Drivers Side
passenger Side
And you do need the conversion lens
-Jameson
Old May 4, 2012 | 01:54 PM
AK Adventurer
Hey thanks, and Wow, that is simple. I know what I'll be getting for next winter.
Old May 4, 2012 | 02:10 PM
  #28
Are the new headlights projector beam?
Hows the light pattern on the road?
Old May 5, 2012 | 01:04 AM
  #29
jgavac's Avatar
jgavac
They are not projector, but reflector. There is a company that makes projector conversion lenses for both square and round, but I think they are more expensive..
The only pictures that I have right now are from a set of lenses that I got at first that were not the right type, but this is a general idea of what the light pattern should look like.
It might be hard to see, but the pattern is huge.
-Jameson
Old May 5, 2012 | 10:35 PM
  #30
Has anybody tried the headlights that eBay sells?
As soon as my parts get in, I'm going to wire up relays to my stock lights, and make my decision from there on aftermarket lights.
Its hard to see in the pic, but is the light pattern pretty solid?
I know when i installed HID'S on my 02 cavalier, it had light and bright spots.
The headlight wasn't made for HID's so the pattern kinda sucked.
The light output was great tho.
rblank
Jan 28, 2019 09:08 AM
Boss_hoss
Oct 27, 2010 10:31 AM
Ryan50hrl
2004 - 2008 F150
18
Nov 10, 2009 02:45 AM
fordtrucklover94
Jun 4, 2008 07:58 PM
