Death Wobble!!!
Old Mar 20, 2012 | 01:09 AM
Iam4x4's Avatar
Iam4x4
Death Wobble!!!
Hey guys thinking of purchasing a 2007 f350 6" lift mud tires etc. he is only asking 10,000 for it because it has the death wobble around 80 KM/H. Does anyone know of a real fix? I heard just ad an extra track bar or add a triple steering stabiilizer package but I want to know if there is a real way to fix it. Thanks
Old Mar 20, 2012 | 01:20 AM
Snuggyworm's Avatar
Snuggyworm
frame is too light for a beast of a machine like that. basically, if ur not towing, keep the front tires inflated to 60 psi and the rear tires inflated to 65 psi. if ur towing, then inflate all tires to 80 psi.
do ur balance and rotation, and of cos, do ur alignment. if all is done and u still got it, then u can add tat traction bar. jus dont jump straight into the traction bar, cos u dont know if the traction bar is the real solution. according to ford, they recommend doing the stuff i suggested first, then try those aftermarket solutions.
best of luck. i hope u love tat car. i know i do.
Old Mar 20, 2012 | 05:30 AM
wulfman's Avatar
wulfman
First off you can't have two track bars and second steering sabillizers don't fix anything they just mask the problem. More than likely the steering componets are wore out check them first . And how big of a tire does it have ? My suggestion take off the lift the truck will never be worth a sh=t like it is.
texbigred1
Oct 3, 2016 08:57 AM
Chris Guthro
Dec 30, 2015 07:19 PM
Steve_2000X
Nov 5, 2007 05:04 PM
armybronco2
Bronco II
Dec 1, 2004 05:35 PM
andersda437
Oct 24, 2004 08:58 AM
