Injector question please help
Old Feb 6, 2012 | 11:16 AM
caiati's Avatar
caiati
Hi guys. So I just took my truck to the shop to have it diagnosed and I have 4 bad injectors. I have a 2006 6.0 F350. I was wondering if anyone had a good online source for the stock injectors so I could buy online. The other four were replaced by Ford when my truck was traded in 17,000 miles ago so I would like to match what they would have installed. Any help would be great!! Thanks!!
Old Feb 6, 2012 | 06:56 PM
Lou Braun's Avatar
Lou Braun
Recommend checking a couple of other things before replacing another 4 fuel injectors. If the injectors are indeed bad, something probably caused them to fail. Low fuel pressure is the most likely problem.
Check fuel pressure first and verify that it is normal (45 psig or greater). Fuel filters that have not been changed, or incorrect replacement filters can cause injector problems.
Check your FICM and verify that it is producing the correct output voltage (48 volts or so). Excellent instructions are in this forum.
With luck, you will not need to replace injectors. I have essentially the same vehicle as yours and have had zero injector issues. Many other folk probably have had no problems.
Lou Braun
Old Feb 7, 2012 | 04:23 AM
caiati's Avatar
caiati
Thanks Lou...... Unfortunately I know why the injectors went bad and it was caused by fuel pressure. My FICM voltage is perfectly fine, I change my filters when I should and I use fuel additive on every fill up. Thanks.
Old Feb 7, 2012 | 08:57 AM
69cj's Avatar
69cj
You should also install the press.reg. blue spring upgrade kit wether or not you have a gauge.
Old Feb 7, 2012 | 09:18 AM
caiati's Avatar
caiati
Thanks cj. That's done already
Jimmy Cash
Jul 12, 2016 07:42 PM
Renneberg
Aug 3, 2014 10:47 AM
TN97STROKE
Apr 29, 2008 04:46 PM
GammaDriver
1997 - 2003 F150
Jan 26, 2007 08:35 PM
Badfunkn
4 Cylinder Engines
May 29, 2002 12:58 PM
