Ok, I have a stupid lug nut question. My wifes excursion which is a 03 6 leaker 2wd (i know this is a 7.3 section but i value your knowledge) has after market wheels. well thanks to the brotherhood i have got a set of factory wheels in the shop waiting to go on. My problem has come with me not knowing what pitch lug nuts i need. Ford tells me its part number 2C2Z1012AA which is a 14mm fine thread nut . Well thats all fine and dandy but with so many options out there i need to know where to find the right pitch. Any help would be great.
If you have an idea what pitch it might be, you can get a few metric bolts of various pitches and see which one meshes with your studs. M10x1.5 and M10x1.25 are common bolts for example and can be found in any decent hardware store for less than 50c each.
Can't you just remove one and take it to the place you are going to buy your lug nuts from? Or as woodbedodge said: Go to Lowes with the nut and the have size fixtures on the wall.
