PHP FICM Programming
Old Mar 18, 2012 | 06:56 PM
Pickupman2004's Avatar
Pickupman2004
Would like to reprogram my FICM with a PHP program. I have several questions.....and would ask PHP, but I can't seem to get a response out of them (tried numerous calls over the last two months and sent in two emails).
With their programmer, can you reprogram the truck with the FICM still in or do you have to remove the FICM? Is it worth buying the FICM programmer that comes with PHP's four tunes? If you were going to rent their programmer, which one of their four programs would work best?......keep in mind that I run SCT tuner with Vivian's tunes.
Any information regarding PHP and FICM programs would be appreciated.
Old Mar 18, 2012 | 07:01 PM
npccpartsman's Avatar
npccpartsman
The only way YOU can reprogram the FICM is with it still in the truck. AFA the level of FICM tuning it's changed quite a bit in the last few weeks. If you go too extreme on it then you can't run a tuner as it maxes out the injectors. Try getting hold of them on facebook or directly on their forum.
I didn't know you could buy their programmer with 4 FICM tunes. I knew you could rent one instead of sending in your FICM.
Old Mar 18, 2012 | 09:46 PM
dlibson's Avatar
dlibson
Not sure I'd run their tunes if you can't get service out of them...
Are you running stock injectors? If so you can't get much outta the FICM tune like npcc said. You'll overrun the injectors...
Pikachu
21
Feb 20, 2014 08:36 PM
1L243
Sep 11, 2013 11:41 PM
GeneLaw1
Feb 12, 2013 09:06 PM
Greek 350
Apr 13, 2012 07:19 PM
Dirtrider0213
Dec 24, 2010 01:42 PM
