Darius
Old Mar 17, 2012 | 01:09 PM
Darius Irwin's Avatar
Darius Irwin
Darius
Hi! I have recently bought a 1989 F350 dually, that has 25,000 miles. I have converted it to gasoline fuel from propane. Engine runs, but it is overfueling pretty badly. I am looking for suggestions as to what the problem could be, if anyone can help, that would be great.
Thanks in advance,
Darius
Old Mar 17, 2012 | 05:30 PM
rla2005's Avatar
rla2005
What engine does the truck have? Have you checked the fuel pressure? Have you checked for any codes? What has been replaced or added to make it run on gasoline again?
Old Mar 17, 2012 | 08:38 PM
Darius Irwin
overfueling 1989 F350
hi there!
the engine is a 5.8l, I have replaced fuel tank, pump, fuel filter, and the injectors. I have checked the vac hose to the FPR and there was no fuel in it.
I have no codes yet. No lights on to suggest a code. Will be looking MAF and other sensors next.
thanks for your reply
Darius
Old Mar 17, 2012 | 08:54 PM
rla2005's Avatar
rla2005
You should get the all-clear code of 11 - 11 if everything passes in KOEO/CM and KOER tests. There can be stored codes even if the Check Engine Light is off. Your truck does not use a MAF meter, it uses a Speed Density engine control system.
Old Mar 18, 2012 | 12:09 AM
deljac's Avatar
deljac
did you mean 125000? if not wow. and welcome to the site
2001Ranger
1983 - 2012 Ranger & B-Series
May 13, 2008 07:17 AM
Baja Tank
Feb 5, 2008 12:27 AM
rodymartin
Aug 27, 2005 11:19 PM
shawn1970
General Automotive Discussion
Jul 10, 2005 07:22 AM
crystalmcdowall
1997 - 2003 F150
Jul 22, 2004 12:03 PM
