Charging problem solved/now starting problem
Old Mar 15, 2012 | 09:47 PM
70-360fe's Avatar
70-360fe
Charging problem solved. If I drive my truck for 15 minutes it starts fine. Drive for 40 minutes or so and it cranks slow and will not start. Let it sit for an hour and it starts right up. Had starter checked 2 weeks ago on truck and it tested fine. I did have a couple times were all it did was click but turn key again and it starts fine. Is the starter going out it is less than a year old. Should I bring it into auto parts store agan and have it tested. Anything else to look at? Charging system still works good. Hate to get another starter if it won't fix the problem. Thanks.
Old Mar 15, 2012 | 11:17 PM
HIO Silver's Avatar
HIO Silver
Sounds like a heat soak issue - either electrically induced or mechanically induced.
For the latter, I'd start with simply loosening the starter bolts and re-seating the starter. The built-up heat will cause metal to expand thereby binding the starter. I'd also check to see if there is a difference in effort between manually rotating the engine when it's hot and when it's cold.
Electrically induced.. have you tried replacing the starter cable? There could be alot of resistance in the wiring - again, a difference between hot and cold states. Plus corrosion will sometimes wick up the cable and not be readily visible.
Old Mar 16, 2012 | 12:00 AM
70-360fe's Avatar
70-360fe
The cables are new and good connection.Good idea on checking by hand and the start bolts I will do that tomorrow. I bought a cheap starter relay
when I had another problem (Did not fix problem) still have the other one and better quality, think I will switch those out too. Not sure if it will help but worth a shot. Thanks
Old Jan 29, 2013 | 08:53 AM
strongbowbert's Avatar
strongbowbert
Sorry for coming late to the party but just joined.
First, most parts stores do not have a clue as to how to properly check a starter or alternator on the bench much less on the vehicle. There are of course a few exceptions. If still having a problem, search out an electrical rebuilder that also does installation, they should if they are worth half their salt be able to check it out properly.
You have new cables, but what size is the cable? Depending on engine displacement, the typical parts store cable could be woefully inadequate.
HIO Silver has given excelllent advice and hopefully the problem has by now been solved.
Old Jan 29, 2013 | 11:17 AM
70-360fe's Avatar
70-360fe
Thanks for the reply, problem has been fixed. After going thur everything above I replaced the wiring harness with a good one I got from J/K and fixed problem. Thanks for the reply!
351Cleveland C4
29
Jun 2, 2014 09:56 AM
Tennesseepowerstroke
1983 - 2012 Ranger & B-Series
Apr 29, 2014 11:20 PM
96broncoXlt
1978 - 1996 Big Bronco
15
Nov 27, 2012 12:37 AM
70-360fe
Mar 16, 2012 09:14 PM
Scopie
Electrical Systems/Wiring
19
Mar 8, 2007 06:35 AM
