Sponsored by: Auxito
Right Front Oxygen Sensor Removal Tricks
Old Mar 28, 2012 | 05:18 PM
kidzstang's Avatar
kidzstang
I'm back to hoping I don't have to take the exhaust off. I moved the pipe off of the manifold and can spray PB Blaster on the inside of the sensor. I added some heat and sprayed it and will do it a few more timed tonight and tomorrow morning before giving it a go again with the impact wrench.
I will also light some incense and drink a toast to the nut god.
Originally Posted by Papa Tiger
If you can get it loose of the manifold you can probably unbolt after the catz and put it in a vise. Rust/corrosion puts the breaks on stuff. You may have to bust the bolts off with the impact.
Old Mar 29, 2012 | 03:19 PM
kidzstang's Avatar
kidzstang
Ok, so I got it and the following is what I think worked best:
1) Separate the exhaust pipe from the manifold.
2) Heat the sensor and spray some penetrating oil into the exhaust pipe and onto the sensor threads.
3) Leave sit and reapply some penetrating oil every so often.
4) From under the truck move the exhaust pipe as far to the right side of the truck as you can and support it so it stays in that position by putting something between the exhaust pipe and the heat shield.
5) Break the sensor body off of the sensor so all that is left is the bolt assembly that is holding it into the exhaust )2 sensor bung.
6) Have a friend heat the outside of the exhaust pipe opposite of the 02 sensor and while that is happening do step 7 as many times and as often and as strength and patience allows:
7) With a 6 pt short socket and long breaker bar slid into a pipe to lengthen the bar for more torque and pushing on the front transmission crossmember with your foot apply as much a$$ as you have to break the sensor loose.
8) Have a beer.
Old Mar 29, 2012 | 05:57 PM
Papa Tiger's Avatar
Papa Tiger
And now you have heard it all. Done it all. Seen it all. Counting down the ten best ways to enjoy an evening with your Ford F150.
Old Mar 30, 2012 | 09:08 AM
kidzstang's Avatar
kidzstang
Yeah, I've seen it all and done it all,,,, at least 'till the next time. Lol
Old May 14, 2016 | 09:30 PM
irishinontario's Avatar
irishinontario
I'm having trouble reaching up to unclip the wiring
Any tips?
Old May 14, 2016 | 09:44 PM
Travis S's Avatar
Travis S
8) Have a beer.
Reapplying penetrating oil that often and letting it soak in was probably the crucial factor. With stubborn or super high torqued hardware, my 240 ft.lb impact does the job well. But for things it can't do, like the infamous 54mm RX7 flywheel nut torqued to 350+ ft.lbs, my go-to tool is a big tree, breaker bar and a come-along. Instant 2000+ ft.lbs of torque...
Old May 14, 2016 | 09:47 PM
irishinontario
Just sprayed WD-40 for the sensor end,
I wss thinking of disconnecting exhaust
Just hope it's the correct sensor! !
Nearest to the passenger wheel and the connector is way up above it
Old May 14, 2016 | 09:56 PM
irishinontario
I just sprayed Wd-40 on the sensor
Going yo take another lash at the connecter tomorrow
I was thinking of the exhaust being removed to get at it but could that lead to another headache
Old Nov 24, 2016 | 01:03 PM
Papa Tiger's Avatar
Papa Tiger
I'm getting new blades for my Sawsall and stop at maggy's for happy hour.
Old Mar 22, 2018 | 04:55 PM
bambam4lsu's Avatar
bambam4lsu
I changed mine after 250K miles, 7/8 box end wrench. Take a grinder cut a 1/8 inch on the top end, feed the wires thru the slot and slips over the sensor.. the rest is history..
Milky1112
13
Jun 23, 2013 05:59 PM
docluv5150
Sep 22, 2012 08:44 PM
eclean
1997 - 2003 F150
May 8, 2011 11:29 PM
enderfd13
Jan 17, 2006 09:04 PM
FoolCrzy
19
Aug 10, 2005 08:56 AM
