Sponsored by: Real Truck
2011 F-350
Old Mar 14, 2012 | 10:39 AM
landscaper's Avatar
landscaper
2011 F-350
Hi guys,
Just changed the oil in my 2011 F-350.
How do you reset the oil life gauge on the instrument panel?
Been going thru the manual... Followed all directions and it still will not go back to 100%?
Any info would be great!
Thanks
Mike
Old Mar 14, 2012 | 11:21 AM
2000silverbullet's Avatar
2000silverbullet
Setting to "New" didn't work?
Set to New or XXX% (Press and hold OK to set).
Old Mar 14, 2012 | 11:22 AM
RAPR's Avatar
RAPR
By using the 'Productivity Screen', you go to 'Settings'>'Vehicle'>'Oil Life Reset' where you can choose to set the oil life at 100%, 90%...etc. Initially the truck will already have 100% selected. Just simply select another value, say 90%, and then go back and select 100% again. It will reset your oil life gauge back to 100%.
Its kind of dumb the way Ford configured this setting, and it takes me a while to remember how to do it each time I change my oil.
Good luck
Old Mar 14, 2012 | 11:29 AM
landscaper's Avatar
landscaper
Hey guys!
Thanks a lot!!!
I re-set it to 90% and then to 100%...... It's all good. Would never have figured
that out!
Old Mar 14, 2012 | 01:18 PM
RAPR's Avatar
RAPR
I will have to sticky this thread, because I know I will forget how to do it by the next oil change. Now if I only knew what parameters Ford uses to measure oil life....since it allows you to start the oil life at less than 100%. GM only allows you to reset back to 100%.
Old Mar 14, 2012 | 01:45 PM
landscaper's Avatar
landscaper
RAPR,
I did what u said and all is good....
'system check' shows the truck is now at 100% oil life
Mike
Brdhunter
May 19, 2018 11:52 AM
Readgriff
Sep 13, 2017 10:23 PM
egregg57
6.7L Power Stroke Diesel
Aug 15, 2016 02:36 PM
dcchadwick
Apr 25, 2016 04:41 PM
willannarino
6.4L Power Stroke Diesel
Aug 20, 2013 07:46 PM
