Oil related questions
1. What is the oil capacity of the V10? (It's not listed in my owners manual.)
2. What weight oil is recommended? (Also not listed in my owners manual.)
3. Are the oil pressure senders finicky? Mine doesn't seem to read low or activate the warning light until there's about 1.5qt of oil remaining. (Don't ask. I do plan to replace it, when the ground temperatures get warmer.)
The following users liked this post:
After the first oil change (where I discovered the EX's penchant for consuming oil) I have kept a close eye the oil levels. It seems that everything is ok through the first 2500 miles after a change. Then it takes a quart every 800 miles or so.
In regards to he the first oil change, I noticed at about 4400 miles, the gauge got wonky. Everything would be fine, but hit a bump, or take a hard turn, and the gauge bottomed out, and the light came on. Within a minute, the gauge comes back up to normal, and the light goes out.
ctaylor57 f100
23
09-19-2011 05:26 AM
