200 excursion missing
Old Mar 15, 2012 | 07:48 PM
jh818's Avatar
jh818
Did it rain recently in your area? Maybe your spark plug boots are old and water got down into the spark plug hole causing a misfire.
Old Mar 16, 2012 | 03:36 PM
chabbio's Avatar
chabbio
Ok guys!!!!! I think its fixed. Pulled another code on cylinder 5. Pulled the coil and put new one in and runs like a champ. I talked to a few people and the plugs that are in here are bosh platinum and they say they are crap. I bought all new motercraft platinum and plan on replacing all of them on saturday. So far so good I will keep this updated if any change. I have been looking all over this forum and it seems like everything comes back to these darn coils. If I could give anyone any advice check all the coils even if you dont get a code.
Chad
Old Mar 16, 2012 | 03:48 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Good advice. We all have to learn the hard way sometimes, including me. LOL. I learned a ton over the last couple of months troubleshooting mine. Still drive it two footed pulling up to stop lights, because of the problem I was having with the bad coil. Good times.
Old Mar 17, 2012 | 02:03 PM
chabbio's Avatar
chabbio
Ok its back. Bought another new coil put it on now reading cam sensor code. Bought a new on and still reading same code. Got another on the way and we will see what happens!!!!!!
Old Mar 17, 2012 | 02:27 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Chad, Are you pulling the plugs off while listening to the idle to figure out which COP is bad? On mine, I could hear the pitch of the idle change, granted I have after market exhaust.
Old Mar 17, 2012 | 10:12 PM
delano0512's Avatar
delano0512
I did the same thing on mine. It turned out to be the passenger side spark plug foiled out due to an old coolant leak( think it was #1, either way it was the closest to the rad on the pass side.) Hope you find the gremlin.
Old Mar 18, 2012 | 05:13 PM
2FordTrucks's Avatar
2FordTrucks
I've been chasing a similar issue. Just now did I get a code to come up and it says misfire on cylinder 8. It has a new plug and coil pack. Going to try to replace the coil pack connector then fuel injector. If that fails then the only other thing would be intake gasket.
Old Mar 24, 2012 | 09:47 PM
2FordTrucks
Any resolve to this yet? I'm still fighting with mine.
my72ford
Feb 25, 2019 09:27 PM
MickGraw
Modular V10 (6.8l)
May 14, 2011 11:52 PM
Chief Mike
1997 - 2003 F150
Jan 22, 2011 09:18 AM
perryg114
Modular V10 (6.8l)
13
Aug 9, 2010 10:09 AM
2000 excursion
May 29, 2006 06:24 PM
