Radiator leak!! fix or replace?
Old Mar 12, 2012 | 02:36 PM
Marlinman10's Avatar
Marlinman10
I have a 87 f-250 with the 6.9 and C-6 tranny. I discovered a small leak up at the top tank near the center. This Radiator is a Modine brand that was new 10 years ago .It has had Prestone green in it and has been drained every copy of years. About two years ago I had a small leak and had it gone through and fixed. Now since I have another leak do you think I should have it fixed or buy a new radiator? Does any one have a brand radiator in mind? And also I've read a little about cavitation and that sounds scary. I would think the motor would be junk if that ever happened. Is this common? I'm the second owner and I really don't know about the maintenance schedule of the previous owner. It had 135,000 when I got it. It has 212,000 on it now and I keep up on all maintenance very well. Which coolant should I put back in it? I've read Prestone isn't the best. The hoses seem fine but I'm going to replace them anyway. Thanks guys..
Old Mar 12, 2012 | 02:49 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I run peak anti freeze or whatever is cheapest. As far as cavitation goes you can get a coolant filter with SCA's in it or just buy the addative from a local heavy equiptment or truck shop. Tell em you need some coolant addative and they should figure it out. I just picked up another jug from our local John Deere, oh can be had from ford as well, but i forget what they call it.
Now the radiator... me personally i would just get a factory replacement rad. and stick it in there. Is the radiator you have now aluminum? If you were running good old fashion green stuff and not the low silica that could be what is eating your radiator.
Old Mar 12, 2012 | 07:00 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
get a new rad. i got a Sila 100% alluminum rad from a local performance shop. was about $300. great purchase.
Old Mar 12, 2012 | 07:24 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
all depends on how bad it is,how long you plan to keep the truck,and your budget.only you and the repair shop can help you decide if its worth fixing or replacing.
i had mine fixed to get me by until i had time to replace it latter because i have plans to keep the truck for a few years.
as for buying coolant,don't run regular cheap coolant if you plan on keeping the truck/engine.it needs to be low silicate w/ sca's to protect the diesel engine.
http://www.oilburners.net/articles/cavitationartic.html
https://www.ford-trucks.com/forums/1...filtering.html
Old Mar 12, 2012 | 09:13 PM
IDIDieselJohn's Avatar
IDIDieselJohn
If you plan on keeping the truck, I'd say go ahead and replace. I've messed around alot with fixing leaks in my rads done by a shop, never holds up for long.
Cavitation isn't very common in 6.9's, but it's a danger in any diesel engine! Run Coolant additives even if it is a 6.9! That goes for any other 6.9 owner out there!
Heres a good read, and understanding Cavitation:
Cavitation Article
Old Mar 12, 2012 | 10:12 PM
mudguts's Avatar
mudguts
I got rotella brand coolant at Napa ith sca's in it.also runing a cooant filter.
Old Mar 13, 2012 | 12:40 AM
Marlinman10
Thanks guys. Lots of good info there!! I plan on keeping the truck. I sure can't afford a new one and I think this engine has a lot of life left. I sure hope so.
Old Mar 13, 2012 | 10:44 AM
'94IDITurbo7.3
here is my sila rad.
Old Mar 14, 2012 | 01:32 PM
Marlinman10
That's a cool lookin radiator!!
Old Mar 14, 2012 | 02:19 PM
Aune163rd's Avatar
Aune163rd
I got several Factory radiators XD!
Old Mar 14, 2012 | 08:19 PM
'94IDITurbo7.3
thanks man
Old Mar 16, 2012 | 12:13 AM
Marlinman10
I picked up two bottles of VC-8 from the local ford dealer.I also picked up a new thermostat and hoses .Mine aren't that old but since I'll have it apart I might as well. I then found the test strips at a Cummins dealer. I can't find Fleetrite Antifreeze anywhere. I checked the International parts dealer,Napa,Orielly and Pep boys .No luck. What I did find was Peak Long Life Antifreeze. It's green and says Phosphate and Silicate Free. 15 bucks a gal.
1. Is this the right stuff for my 6.9?
The article said low Silicate and I assume no silicate is fine.
How about Phosphate free? Is that ok?
Thanks so much.
my current radiator has a aluminum core. Not sure about the tanks.
Old Mar 16, 2012 | 05:43 PM
tecgod13's Avatar
tecgod13
Fleet Charge is what you were looking for. It already has the SCA's added to it. Tractor supply generally has it in stock if you are near one.
Conventional Antifreeze in Heavy
But, if you picked up VC-8, which is an SCA (supplemental coolant additive), you can add that to normal coolant. I'm not entirely sure how it will work with the Peak antifreeze.
I honestly don't know much about how an aluminum radiator changes things. But if you look at the Fleet Charge website above, it should fill you in on some of the details of newer coolants. If you have an aluminum core, the tanks will either be aluminum or plastic (I'm pretty sure on that).
Old Mar 16, 2012 | 06:55 PM
whiteboyslo's Avatar
whiteboyslo
I bet you the O'Reilly store had it but it was in the back. That's the way mine is. I had to ask for it, and even then I had to make sure I asked SPECIFICALLY for the brand. When I initially asked for coolant 'made for diesels', they just gave me a weird look. God bless smartphones, because I was able to look up the name brand on the spot.
Mike
Old Mar 16, 2012 | 07:44 PM
Marlinman10
I think I can get fleet charge at napa and I'll just take the VC-8 back. What a pain. Wouldn't think it would be so tough to get low silicate green antifreeze.
Olds64
21
Jan 8, 2018 08:32 AM
mudguts
Aug 28, 2015 11:01 AM
bskier
Apr 18, 2014 06:55 AM
jeremy.jenson
Feb 28, 2006 12:43 PM
Simek
Aug 24, 2004 01:10 PM
