Upper control arm
Old Mar 12, 2012 | 02:09 PM
Reid lariat's Avatar
Reid lariat
Upper control arm
Does replacing the upper control arm with the ball joint need a pickle fork and compression tool to do the job or is that just when replacing the lower ball joints. This would be done on a 2004 Navigator.
Old Mar 12, 2012 | 06:04 PM
cdherman's Avatar
cdherman
I don't recall useing my pickle fork at all for the uppers. The upper arm is replaced entirely -- ot just the ball joint.
The lower ball joint was VERY tight. I do not know if ball joint compression tools would have done it. In my case, I beat it out with a BFH and then removed the lower arms and pressed the new ones in.
Upper is easy, assuming that you are replaceing the shocks while you are at it. Just bolt on...
Old Mar 12, 2012 | 06:51 PM
Reid lariat
About a year ago I installed coil over springs to replace the air shocks. I am hoping changing the upper control arm is easier than that. Thanks for the info.
Old Mar 12, 2012 | 07:19 PM
bumparker's Avatar
bumparker
A few weeks ago I replaced the front end on a 2003 expedition. Assuming no major differences to a 2004 nav, the ball joint will separate from the knuckle without a pickle fork. You may have to tap/hit the knuckle on the side until they break apart.
You will need a big breaker bar and some deep metric sockets, I can't remember for sure but I think the nuts on the control arms are 22MM. You'll need a 30MM for the bottom nut on the shock and it will be really tight.
I would suggest replacing the lower ball joints as well, mine were perished as were the top. And don't forget the sway bar end links and outer tie rod ends. I bought the lower countrol arms new on Rock Auto and they were cheaper than the upper and I did not have to press out the old ball joints. Suggest buying the good stuff, I used the Raybestos Pro with 2 yr warranty. There is lots of Chinese stuff out there, not sure about the fitment and the quality.
Old Mar 15, 2012 | 10:29 PM
HybridConceptz's Avatar
HybridConceptz
I agree, big hammer. Pickle fork would be nice to have though. rent one, there free
sam hain
1997 - 2003 F150
May 23, 2025 11:39 PM
corner27
2009 - 2014 F150
Apr 5, 2014 05:44 AM
stang3O2
1997 - 2003 F150
Feb 25, 2009 09:39 PM
jez-the-builder
1983 - 2012 Ranger & B-Series
Oct 14, 2008 12:43 PM
jhurd12
Jul 16, 2008 02:48 PM
