MELT DOWN
Old Mar 12, 2012 | 01:03 PM
spikinfool05's Avatar
spikinfool05
MELT DOWN
well my truck tried to burn up the other day. the fuseable link on the battery side of the starter solonoid is melted and i was told smoke came out from under the dash. uncle said he started the truck it ran for a little bit the just died. they smelled smoke the hired man got out and unhooked the battery. i replaced the alternater harness with a diffent one cause the one on the truck was missing the fuseable link. now this happens. i havent really had the time to look at it. any ideas where to start thanks guys.
Old Mar 12, 2012 | 02:21 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Did you replace the harness before the burn out, or after? Sounds like it could have either been incompatible with your truck's original wiring or was hooked up wrong.
There are a bunch of different alternator wiring harnesses. One of the big differences is between gauge and idiot light harnesses.
Old Mar 12, 2012 | 02:44 PM
spikinfool05
before the burn out. both trucks have gauges. the one being a 79 3/4 2x4 and mines a 78 4x4. was all plug and play didnt have to cut or alter anything.
Old Mar 12, 2012 | 04:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I would say you need to look at the dash first and address whatever the problem was with that then go to the alternator harness. You can get replacement fusible links, you don't have to replace the entire harness unless something else in it is burnt also.
Old Mar 12, 2012 | 07:45 PM
spikinfool05
ok any one place to look in the dash first. i got three different harness today at the boneyard for free so im not worried about that
Old Mar 12, 2012 | 09:16 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Not really, try around the ignition switch or light switch then around the fuse block, but the problem could be anywhere in the harness.
Old Mar 12, 2012 | 10:32 PM
fmc400's Avatar
fmc400
MSEE
If you smoked the wiring in your dash enough to drop a fusible link; that entire harness has to come out for a teardown and inspection. Most likely the new harness was installed incorrectly, or there is some year-to-year difference in some piece somewhere that caused the issue.
It takes a LOT of current to blow through a fusible link, so expect to find some nasty goo in that harness. The issue is most likely located around the heavy stuff coming in and out of the ignition switch, or to the headlight switch. Lighter-gauge wiring doesn't usually take out a fusible link unless there are multiple circuits in parallel that are cooking, which also should not happen unless some fatal mistake is made.
Old Mar 12, 2012 | 11:27 PM
spikinfool05
must be year to year or something under the dash wasnt right to begin with. i had no fusible link in the harness for the alternator at all thats why i put the different harness in to just solve the hack job under the hood. next question is who makes a replacement if anyone does? this just kinda sucks i was hoping to get the d 60 im getting up front rebuilt and redo the rear axle also dont do any good if the truck wont run. thanks for your help everyone. when i know what im facing ill let ya know.
Old Mar 14, 2012 | 10:04 PM
spikinfool05
so looking at replaceing the harness who makes one?
Old Mar 15, 2012 | 10:18 AM
kevin316's Avatar
kevin316
Painless wiring harnesses are good from what I hear. You will also get an updated fuse box.
LMC also list a couple in their catalog.
Old Mar 17, 2012 | 06:01 PM
spikinfool05
ok got to look at the truck today noticed while in a hurry to get the truck running the red teminal on the alternator was touching the alternator itself. im thinking maybe this is why the fusable link melted. so maybe i can swap the harness with one i got last week and put the truck back in service. any thoughts?
Old Mar 17, 2012 | 07:49 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Very good possibility. A short in any electrical system is never a good thing.
Old Mar 17, 2012 | 11:45 PM
spikinfool05
so ya think if i replace this again should be ok
joejackF250
Apr 29, 2015 09:05 AM
Queueball
Feb 15, 2013 08:53 PM
facotaco
Nov 18, 2011 01:09 PM
WildPferd
Bronco II
13
Feb 19, 2009 11:02 AM
davidsca
Electrical Systems/Wiring
Apr 11, 2006 08:12 PM
