Air Circulation Around Engine
Old Mar 12, 2012 | 11:03 AM
OneTon4Fun's Avatar
OneTon4Fun
Does the stock fan/shroud set up push adequate air around/over the top of the engine? I am curoius to know if the turbo/exhaust gets enough pass-through air to manage temps at idle.
If air flow around the engine should increase would a better shroud work or would an electric fan with high CFM?
Old Mar 12, 2012 | 04:51 PM
npccpartsman's Avatar
npccpartsman
The factory fan is something like 10K CFM and is temperature controled. It's more than adequate.
Old Mar 12, 2012 | 06:57 PM
critterf1's Avatar
critterf1
X2 if it's operating properly.
Old Mar 12, 2012 | 07:11 PM
69cj's Avatar
69cj
You want compromised air flow in an engine compartment, you should see my 428 cj mustang. In the summer the cabin is a blast furnace. Cooler to leave the vents closed.
Old Mar 12, 2012 | 07:27 PM
rhjj's Avatar
rhjj
The factory fan is not an issue for cooling under the hood, the turbo is cooled and lubricated by oil.
Old Mar 13, 2012 | 09:15 AM
Kert0307's Avatar
Kert0307
Has anyone ever installed an efan on a diesel SuperDuty? I know on gas trucks and SUVs you can usually gain 1-2 solid mpgs by going to an e-fan. But those trucks also have a much simpler fan clutch as well that might not be quite as efficient as ours...
Old Mar 13, 2012 | 11:13 AM
OneTon4Fun's Avatar
OneTon4Fun
I know the stock fan will keep the engine cool. But does the fan adquate to keep engine compartment temps cool with hot tunes? like melted wires?
Old Mar 13, 2012 | 11:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are you planning on removing the stock fan in favor of an electric fan? You'll gain quite a bit of under hood temperatures because there is no electric fan that can move as much air as the stock fan. At least not one that will fit under the hood with the engine still in place...
Old Mar 13, 2012 | 12:44 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Ford built a PTO provision into the engine programming, they had to assume the engine would be used under load while stationary and would need the fan to not just pull air through the radiators but also push it through the engine compartment for all the other components. I don't think just idling the truck could cause any damage (only from a temps perspective), tunes or not.
Old Mar 13, 2012 | 03:28 PM
MisterCMK's Avatar
MisterCMK
The truck isn't going to run as hot at idle as it would with a load cruising down the road.
Old Mar 13, 2012 | 06:02 PM
cheezit's Avatar
cheezit
that fan will pull more air then you could think possibel at 100% duty cycle
parkland
General Automotive Discussion
Jun 13, 2014 02:04 PM
4x4 stepside
Aftermarket Products
Jul 18, 2009 05:46 PM
0270
15
Aug 15, 2004 11:09 PM
Shootit
1997 - 2003 F150
Aug 4, 2004 07:11 PM
mlf72f250
Aug 6, 2002 09:36 PM
