So what did you do to your 6.0L today?
  #12301
Old 02-09-2016, 07:27 PM
AL`'s Avatar
AL`
AL` is offline
Originally Posted by coolfeet
How do I cycle the ABS pump? I am installing brakes later this week.
If you don't have access to a scantool with that capability, then you can do this by driving on a road some place with some dirt or gravel and force the ABS to work. I've found that frequently they can go off too if you brake while crossing railroad tracks. The procedure for bleeding is (1) manually bleed as normal (2) ABS bleed (3) manually bleed again. So it's obviously less convenient without the scantool but it can be done. I'll be doing this myself after I get my new master cylinder put on. I have AutoEnginuity which does have the ABS service bleed capability. It's kind of pricey though.
  #12302
Old 02-09-2016, 07:36 PM
AL`'s Avatar
AL`
AL` is offline
Originally Posted by 87crewdually
Probably air locked. Cycle the ABS pump to assist purge.
I thought so at first too and did exactly that using AutoEnginuity to do an ABS service bleed. When that didn't work I tested my master cylinder by removing the brake lines and plugging the outlet ports per the Ford Workshop Manual test method. It is toast.
  #12303
Old 02-09-2016, 10:50 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
i took it to a drive in fast food place... they need to make them spots a bit bigger...
  #12304
Old 02-09-2016, 11:21 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
With Tacoma voting them selves a $12 min wage and Seattle at $15.
It will soon become Very Slow Food so the workers can get more time
out of each car full. Or in my case no more fast food.Costs too much as
it is and to top that off they only get the order 100% right 75% of the time.
Sorry for the rant.
Sean <BR>
6.0L Tech Folder
  #12305
Old 02-09-2016, 11:26 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
$4 for my food.. 1.76 for the drink... moms food was $7, $5 for her milk shake...
  #12306
Old 02-10-2016, 12:06 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Yahiko- do you have what it takes to cycle the ABS pump on Excursions?
  #12307
Old 02-10-2016, 03:14 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
I should.
What year ?
Sean <BR>
6.0L Tech Folder
  #12308
Old 02-10-2016, 04:52 AM
Bently_Coop
2003 for @USCG_PA brake job coming up, lines and caliper changing. More info in WAFTE section.
  #12309
Old 02-10-2016, 08:46 AM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,132 Likes on 1,446 Posts
Sorry for the rant.
Sean <BR>
6.0L Tech Folder
Still not over that pickle situation from a couple of months ago? I do understand.
  #12310
Old 02-10-2016, 09:22 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Sorry for the rant.
Sean <BR>
6.0L Tech Folder
It's just about as cheap to go to Chili's or Outback and get some REAL food for what you have to pay at the fast food places anymore. Sometimes it's cheaper.
  #12311
Old 02-10-2016, 02:55 PM
evan1242's Avatar
evan1242
evan1242 is offline
Hey guys,
Working on a friends truck doing the blue spring and he still has the plastic CAC tube.
I can not for the life of me get it back on the intake elbow. Looks like I might really have to heat it up?
Any other tricks?
  #12312
Old 02-10-2016, 02:58 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Originally Posted by evan1242
Hey guys,
Any other tricks?
Did you try attaching it to the intake elbow first? It should go right back together, maybe something is fouled up under the air cleaner.
  #12313
Old 02-10-2016, 03:19 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
Hey guys,
Any other tricks?
When cold it can be a *****!! Try lubing it up with Vaseline and lay across the passenger side so you can use you body weight for leverage...
  #12314
Old 02-10-2016, 03:20 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
They can be a pain.stand by the fender and push straight in is the way I've done it.
  #12315
Old 02-10-2016, 05:23 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Did they give them to you this time?
Faster for sure.
Sean <BR>
6.0L Tech Folder
Quick Reply: So what did you do to your 6.0L today?
