CPS Teardown
Old Mar 26, 2016 | 11:44 AM
  #46
Pitcrw6's Avatar
Pitcrw6
Originally Posted by Jaime74656
Ill call and check to be sure its been done then
Don't let them take it if it hasn't been done.
Old Mar 26, 2016 | 12:52 PM
  #47
Jaime74656's Avatar
Jaime74656
ok I was going to ask that, I will keep it as the spare one, and maybe throw one in that they can take...but I will be calling them shortly...
Old Mar 27, 2016 | 12:22 PM
  #48
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Jaime74656... with flashlight and an inspection mirror, you might be able to see for yourself what CMP sensor you have (aka CPS).
If the CPS retaining bracket is gold in color (zinc yellow chromate), and the sensor housing itself is black in color, it is not the recall CMP sensor, and could very likely be original equipment.
If the CPS retaining bracket is silver in color (zinc clear), and the sensor housing itself is gray in color, then those two clues are strongly indicative that the new Ford recall sensor has been installed.
Old Jul 4, 2018 | 06:10 PM
  #49
electryc_monk's Avatar
electryc_monk
Veteran: Navy
(BUMP) for any fresh data to be added to this very informative and impressively researched thread!
/note to self:
check mine & friends CPS for color of retaining bracket and housing.
I'm game to "gently dremel down" to the magnetic surface of the tip on mine *IF* its the Black version.... from IH/BWD. correct?
bpounds
S. California Chapter
Apr 4, 2014 08:30 AM
run6.0run
May 5, 2013 07:45 PM
rmk73
13
Feb 9, 2013 09:28 PM
tinman52
17
Aug 29, 2011 09:18 PM
