390 push rod
Old Mar 11, 2012 | 04:11 PM
Scottie Holland's Avatar
Scottie Holland
390 push rod
i found a bent push rod when i was taking top of motor down to put in a new intake gasket.... do i need to replace all the rods or just one?...
Old Mar 11, 2012 | 04:50 PM
MIKES 68 F100's Avatar
MIKES 68 F100
you can replace the one , but question is WHY DID IT BEND ?
how bent is bent ? lay it flat on some glass and measure the gap
Old Mar 11, 2012 | 04:57 PM
Scottie Holland
it was bent on on Exhaust Valve side ...i can lay it flat on end side my thumn under it in the middle?
Old Mar 11, 2012 | 05:04 PM
MIKES 68 F100
wow that's pretty bent , better check things out
Old Mar 11, 2012 | 05:07 PM
Scottie Holland
could exhaust leak cause it bend like that?
Old Mar 12, 2012 | 04:32 PM
MIKES 68 F100
exhaust leak , no . over reving, timing chain slipped ...
drop a new one in and test everything .
rusty70f100
Dec 4, 2005 05:36 AM
griff22imca
Feb 24, 2005 08:59 PM
97powerstroke
Aug 13, 2004 09:19 PM
Chas1234
25
Mar 7, 2003 12:29 PM
GWB
Jan 9, 2000 02:50 PM
