Interior door panel removal-tips?
Old Mar 11, 2012 | 06:01 AM
74 F350 SCS's Avatar
74 F350 SCS
Hi- I am going to be removing my interior door panels on my 74 F350 regular cab. I know that they are connected by some plastic plugs. Before I start removing them, I'd like to know the best way to do so without causing any damage to anything. Every Ford truck I have ever owned, I have caused some sort of damage when removing them. I have a tendency to sometimes be a bull in a china shop and I am determined, this time, to not do any damage. Is there a special tool, technique, or ???? Any assistance will be greatly appreciated. Thanks!
Old Mar 11, 2012 | 09:29 AM
fmc400's Avatar
fmc400
MSEE
You'll need a door panel popper; it looks like a flat head screwdriver with a forked end. Carefully wedge it under the mounting points of the door panel and gently pop it free. The following will lead to a broken door panel:
1) Using something besides a door panel popper.
2) Inserting the tool and prying under places that are not near the mounting points.
3) Not being careful.
4) Going too fast.
Don't forget to remove the window crank, door handle and finger cup screws in the arm rest.
Old Mar 11, 2012 | 11:37 AM
crsweet78's Avatar
crsweet78
Take a trip to harbor freight and pick up the tools to do it right, theyre cheap and youll end up using them for other trim or door panels.
6 Piece Panel/Trim Removal Tool Set
Panel Clip Pliers
Old Mar 11, 2012 | 11:49 AM
74 F350 SCS
Thank you both for the advice and tips. looks like I'll be headin to Harbor Freight for the right tools. Thanks again!
Dragonking56
Mar 2, 2015 12:49 AM
winr
Mar 31, 2008 08:02 PM
pizalm
Jul 10, 2004 07:35 PM
tplanz
Aug 21, 2003 08:58 AM
PERK
Jul 14, 2003 04:55 PM
