door panels
Old Aug 20, 2003 | 03:44 PM
tplanz's Avatar
tplanz
door panels
I need to take off the driver's side door panel on my 2000 EB Expedition because a piece of the seat memory module fell down in the door. Does anyone know how to take these off. Any help would be appreciated.
Old Aug 20, 2003 | 04:58 PM
buzzard's Avatar
buzzard
door panels
They are really easy to remove....just remember they are removed in an upward fashion, not straight outward. There are three screw points and a couple wire connections. First remove the triangular sail panel near dash and unscrew any screws. Now move to the door handle/power area. Pry whatever you can away (been a while since I removed mine, but it seems there is a little trim piece around the door handle and the power panel) and remove any screws and disconnect power switches. Last move down to the light/reflector area and repeat with prying/screw removal and disconnect harness. Panel is ready to remove...upward only.
Old Aug 20, 2003 | 06:03 PM
PaulC's Avatar
PaulC
door panels
Not hard.
This is from memory:
First step is to remove the triangular shaped piece of plastic trim at the front corner of the window ledge. It is anchored to the top of the door panel and also into the side of the door. Pull the top of the triangle slightly towards you to loosen the serrated plastic spike that holds it to the side of the door, then slowly lift the assembly upwards to remove it from the top of the door panel. Leave your muscles at home for this one (be delicate). I think you may now see a screw that holds the top of the panel to the door. If so, unscrew it.
Next, with your bare hands, pull up the power window switch control panel and unplug the harnesses from the panel.
Then, using a flat bladed screwdriver, carefully loosen the oval piece of trim at the base of the inside door handle and unbolt the handle from the door.
There is a bolt or screw hidden in the housing for the interior door light. Carefully pry off the lens with the by inserting a flat-bladed screwdriver in the slot on the side of the lens.
Next is the actual removal of the door panel. Forget everything you recall about removing door panels on other cars. YOU MUST lift THE PANEL STRAIGHT UP ABOUT 3-4 INCHES TO REMOVE. Do not attempt to pull the panel towards you unless you like the idea of broken, irreplaceable plastic mounting hooks.
Installation is the reverse. Make sure that you line the panel up carefully before sliding it back down. Pay particular attention to the positioning of the door lock button.
Good luck.
Old Aug 21, 2003 | 08:58 AM
tplanz's Avatar
tplanz
door panels
Thanks a lot guys. This board is awesome. This is really good information.
