Running cable for backup camera??
<!-- / message --><!-- sig -->
ffice
ffice" /><o
></o
><o
></o
>Just got it done. Just started ripping the back carpet up and there is a big plug back there very rear drivers side. A small slit and RTV to seal it back and presto. Tucked the cable under the sidewalls, door sills all the way to the front. This back up camera is amazing. Can't wait to hitch the trailer up.<o
></o
ffice
ffice" /><o
></o
><o
></o
></o
>Another spot you can run wires inside is at the passenger side tail light area...up underneath it's all open...I drilled a small hole in that horizontal panel and used a grommet and ran my aux light wires and rear strobe wires through that opening. If you go inside the jack compartment looking aft, there is a hole there as well to get it inside the cabin...if you fish a wire through those two holes, it gives you another access point if you don't want to use the ports under the rear carpet.
In my case I have a large storage box in the back - I didn't want the pressure/weight of that box to damage the wires I would have run through those rubber gaskets you found, so I chose the passenger side option I described above. Took a little concentration to fish a wire through there, but it ended up being a nice, clean install and the grommet keeps it damn near waterproof.
If you aren't as worried about water and don't want to fish the wires, just forward of the piping in the jack compartment - that lower panel goes directly into the opening behind the rear wheel well.
