Ok, I'm stumped. I've been told several different stories about rejetting the carb on my 86 F150. 4.9. A few have told me that Ford leans them out and you can't put smaller jets in, Others have told me that you can rejet the Carb. Whos right?
I've got to think changing the jetting would cause the EEC to freak out. I've you've got to deal wit strict emissions testing you should leave it as it came from the factory.
If you are good with carbs you can clean up the carb throat by removing any cast parting lines and polishing the throat. This will improve the air flow by reducing air turbulance. My experience shows that this increases power and MPGs. However the increases are small (but noticeable) my wife even noticed the ole Plymouth seemed more peppy.
Ford spent a lot of time and money tuning for the best economy/emissions. On an otherwise stock vehicle there's not much to be gained by changing the factory settings.
