steering shaft questions
Old Feb 19, 2010 | 04:54 PM
tbenks's Avatar
tbenks
ive read the oem shaft is not very good, but aftermarket ones run 4 to 5 hundred dollars?? would another oem be ok with my bigger tires? what do you guys think??
Old Feb 19, 2010 | 08:03 PM
F150xlt's Avatar
F150xlt
I believe Borgeson is the the only aftermarket manufacturer for a replacement
intermediate shaft. They use a u joint to replace the rag joint and a spline joint
to allow the shaft length to vary so it can still collapse.
Borgeson Universal Company :: 1970-04 Ford Truck
Old Feb 19, 2010 | 10:52 PM
tbenks's Avatar
tbenks
ok thats good, one that i saw on lmc was almost double that,
so are you saying i should not replace with an oem?
Old Feb 19, 2010 | 11:49 PM
F150xlt's Avatar
F150xlt
The Borgeson intermediate shaft looks like a quality part.
This Borgeson part for a 80-91 has been on E-bay
for a long time. Owner says make an offer.
BORGESON STEERING SHAFT, 80-90 FORD FULL SIZE #000980 : eBay Motors (item 330400090924 end time Feb-28-10 12:03:41 PST)
From what I've seen, the plastic sleeve/insert which is in the middle of the two shafts wears and causes play in the steering. If you separate the two shafts when you reassemble the intermediate shaft the plastic sleeve can be
pushed up into the upper shaft. This causes alot of steering play
Some people say Ford no longer sells the intermediate shaft or parts for it for the 87-91 model years.
Old Feb 20, 2010 | 03:03 AM
Lazy K's Avatar
Lazy K
Good advice from F150 on getting one on ebay.
Also check out summitracing.com for prices.
BigBlueBomb
Sep 24, 2014 08:14 AM
raven3
15
Jun 20, 2014 08:34 AM
ericautopart
Vendor Specials, Discounts, Product Announcements & Group Buys
May 26, 2010 07:07 AM
girlwithatruck
22
May 17, 2009 06:24 PM
eduardo
1978 - 1996 Big Bronco
Oct 11, 2005 12:05 AM
