Tire size an issue??
Old Mar 6, 2012 | 10:35 PM
Powerstrokin_350's Avatar
Powerstrokin_350
I have a 2010 F150 lariat 4x4, crew cab 6.5' bed. Stock tires are 275-65-18 (I believe) and they are goodyear wranglers. The two rears are seperating so I picked up some take-offs as replacements (got all 4) They are Michelin ltx, 275-70-18 off a 2012 F350. They, according to the tire websites for the two tires, are 1" taller than stock, totalling 33.2" tall. Will these fit without a lift?
Old Mar 7, 2012 | 04:17 AM
shotgunz's Avatar
shotgunz
Probably but you'll need your PCM reflashed for the larger tire size or your speedometer and odometer will be off.
Old Mar 7, 2012 | 05:00 AM
svt2205's Avatar
svt2205
275/70-18's fit just fine on my 11. I wouldn't waste your time getting the computer reflashed either. On my 11 everything works perfect with this taller tire.
Old Mar 7, 2012 | 06:04 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Nice to see you back Hank! I thought you were trading yours in for a SD.
Old Mar 7, 2012 | 10:38 PM
stephen.osborne1's Avatar
stephen.osborne1
I have the exact same size and my speedo is dead on now according to GPS... Was a little slow with the old stock tires. As for fit, I have a 2" leveling kit, so I had no issues. I'd imagine there shouldn't be any issue for you either as they are not very wide.
Old Mar 8, 2012 | 06:57 AM
shotgunz's Avatar
shotgunz
Stephen - your results are suprising. Most Ford speedometers are 2-3 MPG fast at 65-70 MPH (it's built into the dash on purpose) but the odometers are dead on.
If your speedometer is now correct, then your odometer is now wrong.
Old Mar 10, 2012 | 08:10 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Thats OK with me, it gives me a few "extra" miles under warranty
Pitcrw6
May 26, 2014 08:12 PM
Rob.D
Jul 12, 2009 09:25 AM
STFXGEO
Nov 21, 2005 05:49 PM
XxfirmanxX
Oct 19, 2004 09:19 AM
