Sponsored by: Real Truck
Tire Size
Old Oct 19, 2004 | 08:49 AM
XxfirmanxX's Avatar
XxfirmanxX
Question Tire Size
What Is The Biggest Tire I Can Fit Under A Stock 2004 F250?
Old Oct 19, 2004 | 08:52 AM
WhëëlMå1's Avatar
WhëëlMå1
Moved to correct forum
Old Oct 19, 2004 | 09:19 AM
igotoneforya's Avatar
igotoneforya
285/75/16 depending on brand is just under a 33' tire which will fit and I know of one F250 that is rolling on 295/75/16 with no rubbing. I think a 34" tire will rub a little. There are wider tires that are the same height if that is your goal. The biggest thing is to look at actual height. Some tires have a larger error than others. There is one 37" tire that measures 36.1 while another 37" measures 37.6. That is a big difference for the same size tire.
