Oil leak!
Old Mar 6, 2012 | 10:11 PM
cooperhale123's Avatar
cooperhale123
Oil leak!
howdy, I have a 95 F250 7.3L truck. I have a steady oil leak coming out of the area of the fly wheel/torque converter inspection plate. I have had this oil leak for months and I have already tried multiple things to fix it. I did the rear main seal and just recently the fuel pump because there was oil in the valley down below the turbo. As of now the valley is dry. So aparently i had more than one oil leak. Im hoping its not the rear main again. Anyone have any thoughts??
Old Mar 6, 2012 | 10:53 PM
Oldsmoky92's Avatar
Oldsmoky92
check the oil plugs on rear of each head. There is no reason for a rear seal to go bad in that short of time. Also check turbo pedastal.
Old Mar 6, 2012 | 10:56 PM
cooperhale123
Do you know how to access those plugs ? And I'm not familiar with the turbo pedestal ??
Old Mar 6, 2012 | 10:58 PM
7DF250's Avatar
7DF250
I just discovered my turbo pedestal is leaking on my 22k mile 97, seems to be common. Is this a difficult repair?
Old Mar 6, 2012 | 11:09 PM
Oldsmoky92's Avatar
Oldsmoky92
The plugs are hard to see let alone get at. I would check out the pedastal first, for this a person must remove the turbo, which is a not to hard if you have skills. My advice is to clean everything really well let it dry start it up and watch. And be certain that your valley area is for sure dry! I recently did my turbo orings and then found out my hpop is leaking also.
LookoutRanch
May 24, 2009 06:51 AM
GreatWhite99
Dec 25, 2008 08:20 AM
phillips91
Aug 27, 2008 06:53 PM
Aussie Jones
Jul 6, 2008 09:47 PM
hdman6
Sep 27, 2006 02:06 PM
