Oil Nightmare
Old Dec 24, 2008 | 12:23 PM
GreatWhite99's Avatar
GreatWhite99
Oil Nightmare
I have been chasing a oil leak for months now, i had put a used good low mileage 7.3 in my truck(when i got the truck the old motor was trash) and have had the oil leak from day one, before i put the motor in i put a new oil pan on, front and rear seal, new oil line o-rings on hpop, new turbo and new turbo o-rings and the o-rings under the pedistal and still have a leak...their is oil in the valley back by the turbo and looks like it leaks down makeing it look like the rear main is leaking, i have read that the pedistal itself might have a crack in it, is it possible and is their and thing else by the turbo that can leak that i missed??? and how can i check for a crack????
Old Dec 24, 2008 | 12:31 PM
MTDewX's Avatar
MTDewX
not sure how to check for cracks.
I put on a new pedistal
http://www.dieselsite.com/index.asp?...ROD&ProdID=237
never had any leaks. it takes one place you can get a leak out of the pic. course I didn't have a leak before so this might not help.
best of luck
Old Dec 24, 2008 | 01:30 PM
harleydude03's Avatar
harleydude03
check the plugs for the injector oil rails. theres one on each side in the back, middle of the valley on the inside ok the heads. maybe ones loose or has a bad o-ring.
Old Dec 24, 2008 | 02:18 PM
SpringerPop's Avatar
SpringerPop
Check the brass plug on the rear of the HPOP, too.
Pop
Old Dec 24, 2008 | 02:23 PM
1996pwrstrk's Avatar
1996pwrstrk
They sometimes leak from the EBPV actuator rod thats in the pedestal . Check that out.
Old Dec 24, 2008 | 02:37 PM
GreatWhite99
I think it is leaking from the EBPV actuator rod or a crack in the pedestal, because oil is pudduling in the back by the turbo and i can't find it leaking anywhere else, can you put new seals on the actuator rod or do you have to buy the whole pedstal new?? If you can put new seals on the actuator rod how hard is it to do?
Old Dec 24, 2008 | 05:30 PM
F350-6's Avatar
F350-6
You could just delete it and keep your old pedestal. Just wire the valve open and gut and plug the opening.
Gut & Plug instructions
Old Dec 24, 2008 | 06:48 PM
Izzy351's Avatar
Izzy351
I may go gut my old pedestal just for fun. I read somewhere that if you do that the oil path through there is opened up between inlet & outlet and you can starve the turbo. Have any of you that gutted it verified that? I have a blank stand from Ron's Turbo Service that doesn't have the cavity where the EBPV actuator goes.
Old Dec 24, 2008 | 07:02 PM
F350-6's Avatar
F350-6
I haven't heard that Joe. I'm not sure how it would open the path more. I just watched the video again and don't see what difference it would make in terms of interrupting the flow from the supply to return side. Am I missing something?
Old Dec 24, 2008 | 07:15 PM
rbaker6336's Avatar
rbaker6336
I read something about that also but can't remember where
Old Dec 24, 2008 | 07:18 PM
Izzy351's Avatar
Izzy351
What I mean is that it connects the two paths potentially bypassing the turbo before the oil makes it all the way up to the oil housing. No idea if that's true or not. I may go open mine up and have a look just to settle my curiosity.
Old Dec 24, 2008 | 07:24 PM
F350-6's Avatar
F350-6
I understood what you mean, but you've changed (or at least seen the side by side o-rings in the pedestal. One us supply, the other return oil path. How does that cylinder way off on the side that just has a spring, rod, and backer plate in it mess anything up?
I'm not saying you're wrong, but if what you read is right, someone will need to explain the oil path to me.
If you decide to play with your old one, maybe you can do your own video we can start linking people too, or show them why they shouldn't do it.
Old Dec 24, 2008 | 09:49 PM
99 7.3 auto's Avatar
99 7.3 auto
to find the leak you can add some Fluorescent Dye. just clean the engine really good add the dye after a day or two (depending on how fast it leaks) look the engine over with a UV light. you can get the dye and the light from most auto part stores. just a thought. good luck
Old Dec 24, 2008 | 11:01 PM
puller45's Avatar
puller45
From the Non-EBV order form
Q. If I disconnect the sensor, some say this will throw a code ,so they remove the turbo, cut the actuator rod off, and tap the hole in the pedestal and put a plug in it with the sensor still plugged. Is this "ok" to do?
A. If you simply plug the hole and leave the sensor plugged in, you may cause yourself the loss of a turbo from lack of oil flow. Let me explain. The same feed port that feeds the turbo bearing is feeding the EBV piston. There is one supply port and one return port in the pedestal. When the EBP sensor sends the signal to the pedestal to shut the valve,which is not there in this case, the oil dumps off to the return port in the pedestal with no resistance. This is the same return port as the one for the turbo. The piston separated the two when it is was properly used from the factory. Basically, while the valve is being actuated or attempted to in your case the turbo gets no oil or very little. The turbo bearing is the highest place in the engine for oil to travel and it will follow the path of least resistance. If you remove this piston in the pedestal, you MUST not allow computer control of the valve any longer. You must disconnect the sensor from the pedestal. Yes, you will get a code (not a light) telling you the valve is non-operational, but it's the only way to do it. "
Old Dec 25, 2008 | 08:20 AM
1996pwrstrk
When Scott and I put my WW in we took the valve out of the exhaust then slipped a piece of hose on the actuator rod with rtv on the end towards the pedestal .This was done almost 2yrs ago I have no leaks and no problems,I of course leave the sensor disconnected. If you think that is where your leak is you could try that.
