help with new gauge install
Old Mar 6, 2012 | 07:22 PM
scottddove's Avatar
scottddove
Installed a set of gauges in my truck. A few issues. Water temp is showing 210 when factory gauge is at half way point, does this seem normal? The transmission gauge will go all the way as far as it can as soon as the key is turned where should I start to diagnose the transmission gauge? (sending unit ?) I went with glowshift gauges
Old Mar 6, 2012 | 08:50 PM
WA_PSD's Avatar
WA_PSD
Call Glowshift tomorrow. They were a great help when I had questions about my install.
As far as water temp. don't know. I didn't install that gauge.
Old Mar 6, 2012 | 08:53 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
1. Ignore the factory gauges. They generally dont move unless there are extreme conditions.
2. Check your connections. Make sure nothing is in the wrong spot, or on the wrong contact.
3. Call GlowShift (haha... Goodluck).
Old Mar 6, 2012 | 08:57 PM
BigAlsPSD's Avatar
BigAlsPSD
Sounds like a possible bad ground on the trans gauge, where did you attach it to? And despite others experience I have never had an issue getting through with tech support.
Old Mar 7, 2012 | 06:17 AM
Tugly's Avatar
Tugly
X2 for the bad ground on your sensor.
Old Mar 7, 2012 | 06:53 PM
scottddove's Avatar
scottddove
I got my ground source from one of the bolts that holds the dust cover on for the flywheel. I guess that may not be a good ground source. So what is the correct temp for the water? Seems like 210 is a bit high. As for calling glowshift I did just that today and had no problems getting thru. They said ground also.
Old Mar 7, 2012 | 06:58 PM
BigAlsPSD's Avatar
BigAlsPSD
What thermostat do you have installed? If it's a 203 that may be accurate. I personally do not monitor coolant temps so have no accurate data for you.
Old Mar 7, 2012 | 08:11 PM
scottddove's Avatar
scottddove
not sure on thermostat. I tapped into the water system on the opposite side of the water neck from the factory location. There was a plug there seemed like a good place.
Old Mar 7, 2012 | 08:12 PM
BigAlsPSD's Avatar
BigAlsPSD
That's where most install it.
Old Mar 7, 2012 | 08:13 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Do you mean one of these holes?
Old Mar 7, 2012 | 10:54 PM
timmyboy76's Avatar
timmyboy76
After inspecting your ground, switch the trans and water gauges. They are the same, and see if you get the same reading again.
1BadHabit
All Other Items for Sale
Jan 1, 2018 05:51 PM
machinist91
Oct 1, 2013 09:56 PM
custom_nirvana
Mar 24, 2008 10:36 AM
rusty9cab
Apr 30, 2007 06:06 PM
jtsmith22
Feb 17, 2004 09:17 AM
