HELP Starter/solenoid problem
Old Mar 6, 2012 | 08:39 PM
fmc400's Avatar
fmc400
MSEE
What happened to the round of checks I outlined yesterday?
Old Mar 6, 2012 | 09:59 PM
roy123's Avatar
roy123
none
Is your truck manual or automatic
Old Mar 6, 2012 | 10:22 PM
Rivergreen74's Avatar
Rivergreen74
Automatic- C6
Old Mar 6, 2012 | 10:27 PM
Rivergreen74
It was 6 volts at the S terminal( even with the key turned to Start). That led me to changing the ignition switch. No change after the switch, it was only after playing with the gear selector and turning the key to start that it turn over. I appreciated your help very much.
Old Mar 9, 2012 | 08:12 PM
71 Sport Custom's Avatar
71 Sport Custom
The neutral Safety switch isn't just an r&r deal. It also needs to be adjusted. It also controls your reverse lights. It has a pin that slides that has to be on the proper side of the pointy arm coming from the column. The arm is held into the shift tube by two hooks that I've seen where just one pops out and it comes out of adjustment. If its cranking as you hold the key and shift it the switch is most likely ok and you'll need to find out why its out of whack. Wear in the column parts and shift collar can cause this. This would certainly cause the bad ign switch symptoms as even though your turning it to start its not getting past the nuetral safety switch.
Old Mar 10, 2012 | 12:13 PM
Rivergreen74
I will have a look at it, hopefully it is just out of adjustment.
blacklab1
Dec 17, 2018 06:46 PM
tjdad62
Feb 2, 2015 12:20 AM
va150
Jun 28, 2012 10:09 PM
lamenytro
Jul 3, 2011 08:51 AM
savag
Feb 19, 2011 03:11 PM
