Brakes?
Old Mar 4, 2012 | 05:14 PM
belas's Avatar
belas
Brakes?
2K f350 4x4 Hey guys, new question for you. Just replaced rotors, calipers, and pads on the front. Got to the passenger side and noticed after jacking it up that the tire would spin, but with some force, then abruptly stop. Got the new stuff on and it does the same thing. I traced steps. One the caliper came off, the hub was spinning freely, one the caliper was on, became tuff again, all this before bleeding the brakes. Any clues?
Old Mar 4, 2012 | 08:24 PM
Smokiesman's Avatar
Smokiesman
Did you replace the brake lines to the calipers? They will collapse internally and act as a check valve! Happened to mine this year!
Smokie
Old Mar 4, 2012 | 08:32 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Check your slide pins.
Old Mar 4, 2012 | 08:51 PM
Mr. Finch's Avatar
Mr. Finch
make sure the pins move freely and the pads move freely in the bracket. make sure the ears (mounts on the calipors) are not bent, that will couse the slides to angle/bend and stick.
rva390
16
Sep 1, 2023 11:09 AM
Smokiesman
15
Mar 18, 2012 12:02 AM
Mr Bill TX
Jun 27, 2011 07:36 PM
strip03
Oct 3, 2005 07:49 AM
90F1505.0L
Dec 26, 2004 08:57 AM
