I am wanting to replace the brake pads on my 03' expedition, but I am not familiar with the clip of the outside of the front calipers. I have had no luck finding a repair manual. What is the process to remove the caliper after removing the two 7mm bolts holding the caliper on?
I didn’t need a hammer to take off the clip; I used a screwdriver to lift it off. Make sure you have the correct size torx or allen to get the caliper off, I used an allen wrench. Replacing pads is easier than you think; wish I had done mine long ago. It takes longer to jack up the truck and pull the tiers off.
I also recommend the ceramic pads. I have had mine on for three weeks and front wheels are still clean, they used to get dirty in two days. Now the backs get dirtier than the fronts. I can’t say enough about them. They are great pads.
...no longer needed on the 2003 Expedition. I searched all over my garage for my T-35 in preparation to do my 2003 and after finally giving up and buying a new one I proceeded to take the front wheels off. Nothing worse than taking apart your ride to the parts house then finding out you need something.
I still have that T-35 brand new on the original card....
My brake pads are due (~30K miles) for replacement. Do I need to replace the rotors also to get rid of that brake dust? Does the dealer uses the ceramics pad to replace the old ones?
from what i understand they use semi-metallic..also you guys that switched the ceramic brakes did you guys notice a difference in stopping the vehicle.
