Dash light color
Those are some great posts I need to look into the cruise control switches but for now I have my hvac blue led and I have on order all the little component LEDs for the door switches dome lights door lights and glove box light when I get all that done I'm going for head light switch and dash then last but not least the cruise control gauges I also have 10 six inch blue led strips placed around the interior under the dash behind back seat behind front seat ect she glows but not really hurts the night forward vision I do have 5% tinted windows all the way around and a glare strip on the front and the blue shows in them but not too bad I'm needing a new clutch bad and hopin to get a 38 r soon
Sounds more like a circuit bord I have never seen a led bulb go out I mean it possible but the led is a solder into the circuit bord looks like a pain to replace but I'm gonna replace y led to blue
Hey boys how's it going. The HVAC control write up can be found in the following album. I used SuperbrightLEDs.com and it went well. Some trial and error but hang in there, don't rush it and you can do it. The HVAC was a bit different in that I needed to use white LEDs around the blue/red temp dial and blue else where so it look correct when illuminated.
Ford Truck Enthusiasts Forums - JPs2003's Album: Blue LED swap out
JP
JP
Here is the pictures for the headlight switch
Ford Truck Enthusiasts Forums - JPs2003's Album: Blue LED Swap Out - Headlight switch
JP
JP
WET BLANKET ALERT! Don't read on unless you can tolerate a little anality.
Red is ideal for maintaining optimal night vision. Blue glow in your face is as bad as it gets. If you're in a metro area - no big deal because you deal with street lamps. I'm in the sticks and the very last thing I want to do is hinder my night vision with a blue dash because I swear... those deer, big-horned sheep, and bear are determined to die by Superduty.
Just a thought.
Just a thought.
Just a thought.
Just a thought.
Ford Superduty - Red LED Map Light Mod - YouTube
Just a thought.
Just a thought.
Blue sucks unless you just ride around town from time to time.
Looks good, no headaches...
Color difference... (fuel level gauge was not avalable when I sent them back to get updated... )
yup.....thats why all the military flashlights are RED! easier on the eyes and harder to see....my stereo can change colors and at daytime i run it blue....at night she goes to red.....as much as i hate red its better on the eyeballs....
The gauge cluster is 74-xHP
The AC pannel is B8.5D-X.
X stands for the color you want (B - Blue, G - Green, etc)
You can get them from SuperBrightLEDs.com
74-xHP: http://www.superbrightleds.com/cgi-b...%2F74-xHP.html
B8.5D-x: http://www.superbrightleds.com/cgi-b...specs%2FB8.htm
Thank you
Gino
Also will these part numbers work for an 05 Ex?
example:
bulbs replaced with LEDs marked with red
89XLTLariatowner
Apr 5, 2005 11:11 AM
